11-02-2021, 02:12 PM
Electric Blanket/Electric Mattress Cover?
We have a 2018 Forester 3011DFS Class C motor home. We also have an electrically-heated mattress cover which we enjoy for taking the chill of the bed in cooler weather at home. We would like to use it in the motor home but only when connected to shore power. However, the mattress instructions says to not use in an RV. Seems to me it should work fine on shore power.
We would appreciate knowledgeable comments on this. If it won't work in the motor home, please explain why. Thanks
11-02-2021, 03:43 PM
Certified Curmudgeon
Fuming
Actually you have a 3011DS. The Forester and the F on your model are a given.
But that is not important right now.
If your mattress instructions are telling you not to use a heated cover and or pad I would think that there is an issue with heat application to the materials the mattress is made from. Most likely that would be fire or off gassing.
As far as electricity goes, that does not make any difference.
Mike Dropped
11-02-2021, 05:49 PM
I think it should be DSF, the DS meaning double slide, and the F standing for Ford chassis. As you said, not important.
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
11-02-2021, 06:01 PM
I should have worded my question more accurately. It was the electric mattress cover that said don't use it in an RV, not the mattress. Sorry.
11-02-2021, 07:09 PM
It is DSF but the 3010/3011 only comes on an F so it is superfluous.
Mike Dropped
11-02-2021, 07:14 PM
I see. In that case I suggest contacting the cover manufacturer and inquiring as to why. There are so many different RV mattresses that I do not understand how a cover manufacturer would know or be able to discern between a residential and RV mattress. I for one would sure like to hear their answer.
The only thing I can think of is that the cover manufacturer thinks all RV mattresses are short (like yours) which could cause the heating element to bend over the edge and malfunction.
Mike Dropped
11-03-2021, 07:18 PM
We have used an electric mattress pad in our travel trailer and currently in our 5th wheel. Never had a problem, but a warm bed to climb into is wonderful.
11-03-2021, 08:52 PM
May I make a suggestion? Instead of an electric mattress cover and blanket why not use a Flannel sheets with a Down Blanket. That is what we use when we are in our 5ER for fall and early spring camping. We are extremely warm during the night and usually have the one window open in our bedroom when we are sleeping.
We use to use an electric blanket but didn’t like the static electricity that the blanket would give off. In fact we have three different Down Blankets, one very light for early fall sleeping, then a medium Down Blanket we use when the night temps are in the 40’s at night. We use a 144 once blanket at home during the winter months, when the night time temps are in the negative area. We never have been cold at night and sleep very well at night.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
11-03-2021, 09:02 PM
OP, that instruction would appear to make no sense as long as the pad fit properly. If you used the same mattress inside your home the electric pad would okay but not in the RV? ppffffft. As suggested above I'd contact the manufacturer if possible and otherwise would not worry about it.
2021 2205S Rockwood Minilite
2019 F 150 Lariat 3.5 Eco Fx4 Max Tow
Equal-i-zer WDH, 1809 lb payload
11-04-2021, 01:13 AM
I have a 9V outlet next to my rv bed that I plug in a 9V travel blanket. (Great when you don’t have 110v available.) It works really well on cold nights. It can be plugged in up front also while traveling. I bought one at a large truck stop. I bought a second one on Amazon.
11-04-2021, 08:13 AM
Thanks, Everybody for the help. We will simply use the electric mattress cover in the RV. Happy Travels. Bob
11-04-2021, 08:43 AM
NeX and don’t forget the battery in the smoke alarm…
Now I will ponder why somebody would have a 9V outlet in an RV. I love a good mystery.
Mike Dropped
11-04-2021, 08:01 PM
We have migrated a residential queen heated mattress cover into our RV that has a short queen. We just make sure that it is installed so that the heated portion is fully on the mattress. On ours, the heating element does not extend all the way to the head of the pad. Elements are denser at the foot and less so in the "mid body" area. No elements at all under our heads - much to the chagrin of my DW who always complains her head gets cold at night.
Great being able to climb into a warm bed on a cold night.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
11-24-2021, 11:16 PM
I know the op has decided to use the heated cover, but I noticed some replying to something that wasn't an issue. The op said the mattress cover instructions said not to use it IN and RV, not on an RV mattress. So I'm wondering why. Fire threat?
2018 Forester 3011 DS
11-25-2021, 10:33 AM
I would think so, Thats is why I suggested Flannel sheets and a Down comforter. No fire hazard.
Jim W.
