02-15-2015, 12:46 PM
Engine Size
How do I determine the exact size motor in my 2012 Sunseeker 2450S? It is a Ford chassis. The sticker near the radiator says it could be 4.6L (highly doubt this), 5.4L (doubt this too) or 6.8L (think this is it). I thought the Ford would have a V-10 badge on it if it was the 6.8L, but there isn't one. I bought it used so there isn't a lot of documentation with it.
The reason I want to know is so I can determine how large of a vehicle I can pull behind it. Most likely the vehicle would be a 2 door or 4 door Jeep Wrangler.
2015 Jeep Wrangler Toad
02-15-2015, 12:49 PM
I would go to a Ford dealer with the VIN number and have them check it out for you.
02-15-2015, 12:56 PM
Unless you want to crawl around the engine looking for the block stamp, if it's a v 10 just count the plug wires or (coil packs if that's what they use).
My wife keeps saying I don't listen to her -Or something like that?...."My advice has no basis ,more reliable them my own meandering experience" Baz Luhrmann
2011 Sierra 355QBQ 1986 F350
02-15-2015, 01:02 PM
I don't know what information is coded within Fords VIN's, but this may save you a trip to the Ford Stealership...
VIN Decoder | fleet.ford.com
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2021 Solitude 310GK w/FBP
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
02-15-2015, 01:03 PM
If the eighth digit in the vin is a "S" you have the 6.8l V10
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
02-15-2015, 01:04 PM
I believe it would also have ten spark plugs.
02-15-2015, 01:08 PM
Yes it would have ten plugs but a LOT!! easier to check vin then start counting plugs Unless your into that thing!
2014 Forester 3051s
2012 Sonic toad
02-15-2015, 01:12 PM
I usually have grease stains on my fingers and clothes so one could say I'm into that sort of things.but you only have to count 5 on one side so you only need to use one hand right?
02-15-2015, 01:21 PM
I have seen the 5.4L in our motorhomes. Just the small class C's.
02-15-2015, 01:40 PM
Type the vin number off your door into this. It will give you the window sticker for your chassis. Just make sure to use the Ford vin and not the forest river one.
http://researchmaniacs.com/VIN-Numbe...cker/Ford.html
02-15-2015, 01:51 PM
02-15-2015, 04:21 PM
Thanks for all the replies.
Next question: Where do I find the GCWR? Neither sticker inside the door shows GCWR. They show GVWR, but that is all. Is GCWR the GVWR (14,500 lbs) + towing capacity (5,000 lbs) = 19,500 lbs?
02-16-2015, 05:45 PM
Commercial Member
No, the GCWR is whatever the chassis is rated at.
the E450 got bumped from 20,000 to 22,000 back in 2010 methinks.
02-16-2015, 06:14 PM
Do you have any idea how to verify the numbers? Now that you say 20-22,000 I thought I saw 22,000 somewhere.
Eric
02-16-2015, 06:23 PM
Commercial Member
Yours is 22,000 if it's an E450 from 2012.
I was simply saying that pre-2010 it was 20,000lbs. They increased the brakes and it now sits at 22,000 GCWR (or it could have been 2008 when they changed)
You can also look at the 10th digit of your VIN
A is 2010, B is 2011, C is 2012, D is 2013, E is 2014, F is 2015
Then you can pull up the specs from ford for your model year to determine GCVR.
Or trust me when I say its 22,000.
