Old 01-14-2023, 07:46 AM   #1
Eternabond roof taping..
I'm going to type my RV roof... seams & around all roof assessories... with EyernaBond Tape. I see EternaPrime spray adhesive is an additional option for better long term adhesion. Is this spray necessary?... Does it really make a difference?
The spray is $30/can and an additional step in the process, so I would appreciate comments from anyone with experience.
Thanks.
PapaDee
Papa Dee is offline   Reply With Quote
Old 01-14-2023, 09:39 AM   #2
Kanadian Kamper
kenandterry's Avatar
As with most adhesive products, prep work including detailed cleaning is key to it’s performance. Lots of discussions have stated you should clean with isopropyl alcohol for Eternabond to seal properly.
I suspect you’d find this EternaPrime has this as an active ingredient, and helps with sales, but I’ve never seen it in person to read the label.
I do know that the discussion about Eternabond has been going on for as long as there’s been RV roofs, and I’m sure others will chime in.
Ken and Terry
Former Georgetown 330TS owner for 10 years with more mods than I can count
kenandterry is offline   Reply With Quote
Old 01-14-2023, 09:42 AM   #3
yukongold's Avatar
I Eternabond-ed the entire roof of my MiniLite early in the third year I owned it. I did not use the spray you are talking about and all of the tape was still in great shape when I sold it last fall - - well after seven years of use and several cross-country trips.
I did use Dicor self-leveling caulk at all of the leading edges, though. Might not have been needed but it gave me just that little bit more peace-of-mind that 60-65 mph wind (highway speeds) would not get under it and pull it off. Strong wind can do some serious damage - - just look at some of the hurricane damage photos.
I plan on doing my new trailer this spring. Won't bother with the adhesive.
2007 Sierra 2500HD Duramax | ECSB
2012 Rockwood Minilite 2104 - Sold 07/2022
2022 SOB 29' 5th wheel - purchased 09/2022
yukongold is offline   Reply With Quote
Old 01-14-2023, 09:47 AM   #4
Thanks for the insight & and info. Most things I have read says..."Clean roof well, place tape and really roller stick down." Think I'll forego the spray adhesive.
Papa Dee
Old 01-14-2023, 10:56 AM   #5
Eternabond tape is very very sticky. Once properly applied it doesn't come back off easily. I see no need for extra spray.
Iwritecode is offline   Reply With Quote
Old 01-14-2023, 11:06 AM   #6
Chuck_S's Avatar
My Eternabond tape went on the roof in 2005 and is still perfect but the recommended $30 can of spray adhesive is too minor a expense to even think about.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 01-14-2023, 11:28 AM   #7
I cleaned with alcohol and put down the tape. It doesn't need help to stick, it's incredibly sticky as is..
1100mike is offline   Reply With Quote
Old 01-14-2023, 12:29 PM   #8
Certified Curmudgeon
Duckogram's Avatar
Maybe
I used some to remove black/green/red mold which isopropyl alcohol would not clean. I also used it to remove silicone residue which eternabond tape did not adhere to well.
That said, I feel it is unnecessary in most instances where the surface is clean and prepped with an isopropyl wipe down.
Note: This is cleaner and not prime.
ID:	283063   Click image for larger version
Welcome to Lake Wobegon where Justin and David utilize abductive reasoning to help solve F/SS issues.
Happy Trails and Remember the Pequod.
Old 01-15-2023, 03:56 AM   #9
Thank you for the tips & experience.
Papa Dee
Old 01-15-2023, 09:04 AM   #10
llibdliw's Avatar
Eternabond Tape
Type EternaBond Tape in the search bar above and you will get hours and hours and hours of reading.
Also YouTube has many videos of EternaBond Tape application.
Hope this helps...
Wild Bill
2019 FR Rockwood Mini Lite 2109S
2022 RAM 1500 Bighorn, Quad Cab, 5.7 Hemi, 3.92 gears
To get better, you have to get better at what you are doing to get better.
llibdliw is offline   Reply With Quote
Old 01-15-2023, 11:27 AM   #11
rsdata's Avatar
I have posted about my Eternabond experiences twice over the years
GOOD DECISION with or without the added spray... just pick a warm DAY and not a HOT day
https://www.forestriverforums.com/fo...nce-90060.html
https://www.forestriverforums.com/fo...oo-238605.html
2014 Shamrock 183
Old 01-26-2023, 11:25 PM   #12
I didn't use spray and it was still stuck several years later when I replaced the roof. Cleaned with alcohol and something else that EB recommended cleaning.
Tip- get a good roller and use knee pads.
The roller I used is not available now, but was heavy and smooth:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
garywilson is offline   Reply With Quote
Old 02-01-2023, 10:40 AM   #13
Did mine 2 years ago without the spray. Cleaned good with alcohol prior to using the tape and have had no issues whatsoever. As good as that stuff sticks, IMO the spray is a waste of money. Be careful using the tape…if you accidentally stick it to something unintended, it is real tough to get off.
2020 Palomino Solaire 316RLTS
2017 F-250 6.2L
Richbo69 is offline   Reply With Quote
Old 02-01-2023, 11:31 AM   #14
2022 Dynamax Europa
I'm a big fan of Eternabond. When applied properly it will last 20+ years. DO NOT buy the knockoff brands as they are crappy--stick with the real stuff. As far as the cleaner and primer, I found it worth it. Although expensive, the Eternaclean will prep the surface properly. It is hard to find but I came across one company that has some.
https://www.amazon.com/EternaBond-Ou.../dp/B004LF3HQO
https://www.amazon.com/Eternabond-Et.../dp/B01BCPC7Q6
M_I_A is offline   Reply With Quote
Old 02-02-2023, 03:15 PM   #15
Now half way through the roof taping process. Have had only one afternoon of good weather since first posting. It has been ultra cold or raining every day since. The afternoon I was able to work, all went well until dusk when the dew fell. I could not keep the roof surface dry and the last piece of Eternabond would not stick.... learned a good lesson. Work on a warm dry day!!!
I will resume work when weather permits!
Papa Dee
Old 02-02-2023, 03:21 PM   #16
Nope
See the MSDS.
Larry
Larry-NC is offline   Reply With Quote
eternabond, roo, roof
