Old 06-08-2016, 11:09 AM   #1
Puzzlme's Avatar
Exhaust pipe dripping water
I'm wondering if there are factory installed drip holes in the exhaust pipe between the engine and the muffler? I have two places that drip right at what appear to be joints in the pipe.
2013 Sunseeker 3010
https://rhodaventure.com/
2013 Sunseeker 3010DS
2014 - 15,000 Kilometers (9360 Miles) Alberta through the US to E. coast, up into Atlantic Canada, Newfoundland and back.
2015 - 2 great trips so far. Alberta to Oregon coast, Alberta to Shushwap in BC.
Puzzlme is offline   Reply With Quote
Old 06-08-2016, 03:55 PM   #2
grumpy0374's Avatar
Only place I've ever seen drip holes in an exhaust system is the muffler. Usually hole at each end near the crimp or welded end.
If your is leaking at a joint where two pipes come togather via a clamp or flange, it may just need to be tightened. If it's at a bend or somewhere at a place where the pipe was bent (sometimes there will be "crinkles" from the bend), then you have a hole that should NOT be there.
May need to get it welded over or replaced.
Grumpy
Steve & Cheryl + Zoey, and Ziggy, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
grumpy0374 is offline   Reply With Quote
Old 06-09-2016, 04:40 PM   #3
Chief tinkerer
Gidyupgo's Avatar
Exhaust pipe dripping water? Oh, you must be referring to the new water cooled exhaust system........ ooops, sorry, couldn't stop my thumbs from saying that.
I have had drips out the tail pipe end while idling after first crank up in the mornings. Condensation I guess.
Gary
2017 SunSeeker 3010DS
Gidyupgo is offline   Reply With Quote
water
