Old 05-12-2017, 06:48 AM   #21
Wolverine 1945's Avatar
Originally Posted by ajpmorin View Post
Yes, same here, I purchased a roll of the plastic trim and replaced it. I figured the stretched it when it was originally installed.
Your probably right about the stretching,,, like every step in building RVs & Manufactured Homes it is done in what ever manner gets it done the fastest !!!
Wolverine 1945 is offline   Reply With Quote
Old 05-12-2017, 10:11 AM   #22
Rvrphdawg's Avatar
Found several different brands/ sizes of trim on Amazon. If anyone ordered one that for their Sunseeker, please post link. Rv is in storage and can't get to it to measure width
Rvrphdawg is offline   Reply With Quote
Old 05-15-2017, 08:33 PM   #23
Width is 1 inch.
2014 Sunseeker 2300 Chevy
Snowman9000 is offline   Reply With Quote
Old 05-16-2017, 04:54 AM   #24
DouglasReid's Avatar
Originally Posted by dbareford View Post
My trim that covers front cap seam and runs down front edge of unit keeps popping out at curve between top and unit. Anyone else have this issue? Can you just crazy glue it in? Attachment 136732
as they age the seem to shrink, causing that problem. My solution is to simply replace them when that happens. You can buy the stuff in 100' or 50' rolls
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 05-22-2017, 04:05 PM   #25
Here are a some I found on Amazon, any suggestions which is better?
https://smile.amazon.com/Camco-25202...%22+white+roll
https://smile.amazon.com/Camco-25103...QG21M9XG1G2MJK
https://smile.amazon.com/RV-Designer...QG21M9XG1G2MJK
https://smile.amazon.com/Insert-Mold...QG21M9XG1G2MJK
Emil Faber is offline   Reply With Quote
Old 05-23-2017, 08:24 AM   #26
I believe if it is properly installed it should not need to be replacing !!!
Maybe it should be pre srunk ??? You must install as much as possible !!!
Old 05-23-2017, 09:41 AM   #27
I looked at the links you provided. As I posted above I purchased my trim from Ebay as it stated in their listing it is UV protected and made in the USA. If your rig is white I would purchase the white but if its more of a off white buy the colonial white. I have the full body paint and it was almost a perfect match.
Desertsquid is offline   Reply With Quote
Old 05-23-2017, 09:51 AM   #28
so i'm not the only person with that problem! ours is coming loose under the 5th wheel cap where it bends to go down the front of the body. we have full body paint with stripes. but to start i'll loosen the end and push it up so that it is not stretched at the bend. then the wife may get to practice her arts and crafts talents to do any required touch up. I learn something every time I visit this forum!
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 05-23-2017, 10:04 AM   #29
I would try to install it,,, leave it a few inchs long,,, for a few days if possible !!!
In hopes it would shrink !!!
exterior
