Old 10-30-2017, 08:46 AM   #1
Exterior TV during winter
I have an exterior TV mounted behind a storage door. Wondering if it needs to be brought in or left in place.
GMax is offline   Reply With Quote
Old 10-30-2017, 08:50 AM   #2
Chief tinkerer
Gidyupgo's Avatar
Gmax, ours is too and we have not had any problems with moisture, etc.
Gary
2017 SunSeeker 3010DS
Gidyupgo is offline   Reply With Quote
Old 10-30-2017, 09:11 AM   #3
Thanks. 1 check for leaving as is.
Old 10-30-2017, 09:20 AM   #4
DW's 401(k) Plan
DaGrinch's Avatar
Well, being tho our 3010 will be in storage, I take all my TV's out and put them in a closet in the house.... Takes maybe 5 minutes total to take them off. Almost the same amount of time to put them back in the spring.
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
DaGrinch is offline   Reply With Quote
Old 10-30-2017, 10:03 AM   #5
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Cold weather will not damage electronic equipment, moving it in and out of the rv .... that's a different story.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
Cypressloser is offline   Reply With Quote
Old 10-30-2017, 10:14 AM   #6
Bill and Gail's Avatar
I leave mine in place in my 3010DS
Bill and Gail is online now   Reply With Quote
Old 10-30-2017, 11:17 AM   #7
Over the years I've noticed that opinions are split almost 50/50 on leaving TVs in or taking them out over the winter. Personally, I know of at least one couple that had theirs freeze over the winter and they had to replace it. So I always bring mine home.
Possible theft is another consideration depending on where your RV is stored.
Iwritecode is online now   Reply With Quote
Old 10-30-2017, 12:38 PM   #8
camaraderie's Avatar
Samsung says:
"The operating temperature range for Samsung LCD monitors is 50 F to 104 F (10 C to 40 C). The safe storage temperature range for Samsung LCD monitors is -4 F to 113 F (-20 C to 45 C). Temperatures outside these ranges can cause LCD monitors to malfunction."
I assume other TV mfrs would say about the same. So...it depends where you live I guess...and I would also take the precaution on NOT trying to turn the TV on until temps get above 50 degrees in the coach or outside as appropriate.
________
Cam
2015 Georgetown 280DS
camaraderie is offline   Reply With Quote
Old 10-30-2017, 01:01 PM   #9
To Store Or Not To Store
Hi,
I Agree with Cam. I've been in electronics for most of my life, and agree with Samsung's statement regarding temperature extremes. It's not good to expose electronics of any kind to temp extremes, let alone LCD TV's; it's asking for trouble. I always take ours off the mount and bring it indoors during the cold months.
audiocentric is offline   Reply With Quote
Old 10-30-2017, 01:04 PM   #10
CaptnJohn's Avatar
Mine have stayed in various units for decades ~~ never a problem.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
Old 10-30-2017, 01:26 PM   #11
TV in Winter
I have a 2014 3050SF and have always left it installed. It has made it thru the Buffalo, NY winters every year
RetiredAF1955-1981 is offline   Reply With Quote
Old 10-30-2017, 01:43 PM   #12
Thanks everyone. It was just one bolt between leaving it on or taking it off for the winter. I was in the winterizing mode, so I removed it.
Old 10-30-2017, 01:59 PM   #13
Just as confused as you
Scrapper's Avatar
If you have a LED (Light Emitting Diode) tv you won't have a problem. A LCD (Liquid Crystal Display) is another beast, the crystals will freeze and swell.
Richard & Jill
Old 10-30-2017, 04:39 PM   #14
IN 14 years of RVing, I've never removed any electronics from the units I've owned. No issues to date.
John C
JOhn_R_C is offline   Reply With Quote
Old 10-30-2017, 04:57 PM   #15
If cold weather is not an issue for electronics in Canada why would it be south of the border.
Lithium Ion batteries, like the ones you'd find in cordless tools, cellphones..., on the other hand don't hold a charge in cold weather at all. My cellphone goes from 100% to almost 0 in a matter of minutes in - 30 weather if I don't keep it close to my body.
Ordered: 2021....
Old 10-30-2017, 06:17 PM   #16
LED TVs are actually LCD TVs with LEDs for back lighting, so if cold temps are a problem for LCDs then LED TVS still have that problem. LCD TVs were back lit with fluorescent lamps before LEDs came along.
2017 Forester 2861DS
towing 2015 Jeep Rubicon
fobagbob is online now   Reply With Quote
Old 10-30-2017, 07:38 PM   #17
X2...ditto for OLEDS too!
________
Cam
Old 10-30-2017, 07:42 PM   #18
DW's 401(k) Plan
DaGrinch's Avatar
Both - weather AND theft - are the reasons I take mine out. It can get kind of cold here in Western Maryland, plus being stored away from my house make it an easy decision.
Old 11-03-2017, 03:27 PM   #19
Scrapper's Avatar
That's not quite correct. LG is the largest maker of OLED screens, until recently the only maker. The reason OLED TV's are so expensive is that each pixel creates it's own light, no back light is used.
OLED screens are the thinnest made, they are thin enough they can be bent, folded or even printed onto clothing.
How OLEDs (organic LEDs) work - Explain that Stuff
What is OLED TV? - Definition from WhatIs.com
I think I want to replace the cover on my front window with a OLED.
Richard & Jill
Old 11-03-2017, 03:41 PM   #20
Ditto on all that but all I was trying to ditto was the storage and op temps issue.
For the record LG oleds work 32-104 degrees.,.store from -4 to 140 F .
exterior, winter
