Old 07-05-2014, 06:39 PM   #1
extra rods
I hate to be dumb ass but my wife and I were packin for our first trip in 0ur 3010 and we have 3 plastic rods with rubber caps on each end. they were in the cabinet above the sofa. we have no idea what they are for. any help would be great
walterhess is offline   Reply With Quote
Old 07-05-2014, 07:04 PM   #2
Orion's Avatar
extra rods
Likely an accessory you can get to try to keep stuff in place in the fridge or cupboard.
Something like this. Could be single bars also..
http://www.amazon.com/Camco-44073-Do...xgy_auto_img_y
2017 Flagstaff FLT21DS
2011 Tundra Platinum, 5.7l, 2WD, Firestone bags...
Orion is offline   Reply With Quote
Old 07-05-2014, 07:17 PM   #3
They are 18" long hollow aluminum rods with rubber caps on each end. cant find anywhere they fit and could be used to keep cargo in place.
Old 07-05-2014, 07:44 PM   #4
raoulwv's Avatar
Those rods are to prevent the slide-outs from drifting out should you ever have a slide-out failure. They are placed between the wall and the slide frame.
Rod & Carla B.
The Hounds Kooper & Abby
2022 Fleetwood Bounder 35K; '18 Ford Focus toad
Owned 2015 Sunseeker 3010DS previously
raoulwv is offline   Reply With Quote
Old 07-05-2014, 07:45 PM   #5
I found three or those in my 3010ds also. I think they are for the side slide, they seem to fit between the slide trim and the inside coach wall when it is closed. Will prevent slide from opening while moving. The Rockwood 1809s TT I had also had one, though it was adjustable, and in the walk-thru I got, it was explained to be for that purpose.
2014 Sunseeker 3010DS
With chocolate, all is well
richardwise is offline   Reply With Quote
Old 07-05-2014, 08:00 PM   #6
Ford Idaho's Avatar
Sounds good to me.
@ OP
Tie two of them together with some rope and use them nunchuck style on the dealer that SHOULD have explained them to you.
Old 07-06-2014, 05:52 AM   #7
Mike & Molly's Avatar
They are used to prevent the side from moving while traveling. Most important if the slide motor or tracks have a problem. Make sure they are removed before opening a slide - if not mega damage can/will occur. I put a note over the slide button to remind me.
Mike & Molly is offline   Reply With Quote
Old 07-06-2014, 08:30 AM   #8
tmhyer's Avatar
This was answered in previous threads. Theyre for the slideouts
tmhyer is offline   Reply With Quote
