07-03-2018, 12:30 PM
EZ Pass
I just bought a C class and was wondering if putting the EZ pass under the mirror will get picked up by the toll booths because of the cab? Thanks.
07-03-2018, 12:35 PM
I think some people have had issues with ez pass reading the transponder with the class c when on the windshield. I would just get a transponder that attaches to your license plate.
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Bruce" 2011 Dodge Durango V8 Hemi Crew
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
07-03-2018, 12:39 PM
Yep, several reports here of EZ-Pass issues in a Class C.
Some even had issues with it as far forward on the dash as possible, others didn't.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel•Goodyear Endurance Tires•2017 Ford F-Series SCREW 4x4•Factory Puck•B&W Companion•TST Tire Monitor w/Repeater•Sinemate 3500w Gen.
Days Camped: '17=38 ☼ '18=49 ☼ '19=58 ☼ '20=110 ☼ '21=116 ☼ '22=88
07-03-2018, 02:22 PM
I’ve only seen the transponders that attach to the windshield. Where do you get one that attaches to your plate? I didn’t see this option on the ez pass website
07-03-2018, 03:00 PM
Indiana will add to the fee if they see the transponder is not in or close to where they want it. I'm in Illinois and just leave mine on my dash. For my last loop through the east coast I mounted it where it should be.
https://chicago.cbslocal.com/2013/03...nder-problems/
07-03-2018, 03:04 PM
Originally Posted by Reprise
Thanks. I still have my PA EZ pass account, even though I don’t live there any longer, since we travel back enough to make it worthwhile. I guess I could look into creating a separate account in Md or NY if I need the license mount.
07-03-2018, 03:12 PM
Kasual Kamper
If your Class C has a window in that forward bunk, you can try mounting the EZ Pass there.
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
07-03-2018, 03:44 PM
It has always registered for me.
07-03-2018, 04:17 PM
PA required me to use a license plate mount transponder. It is also coded in the system for my RV rather than a car. Havent had any issues in the many states I've used it in. You have to call them to get the outside transponder.
I used security screws (torx with a center pin) to secure it to the front plate mount.
2021 Newmar Baystar 3401
2019 Jeep Cherokee Trailhawk toad
2017.5 Forester 3051S Traded 7/2020
07-03-2018, 04:19 PM
we put ours above the dash, about 3 inches, worked fine
07-03-2018, 04:40 PM
Sad that you felt you had to use security Torx screws. Anyone who would steal a transponder, thinking they could use it freely on another vehicle, has to be a candidate for one of those 'stupid criminal' awards.
AFAIK, every state that uses automated toll collection has the capability of photographing the front *and* rear of your car if you pass through w/o a transponder (this has happened to me), and records are kept of every toll taken.
07-05-2018, 08:51 PM
X2
07-06-2018, 07:33 AM
The I-pass worked just fine for me placed inside the cab and just behind the rear view camera (inside, on the windshield). You can check your account online to see if a payment was subtracted from your account.
Charlene
and catpanions, Purrl & Lucy Lu
2014 Solera 24S
07-06-2018, 09:19 PM
I put mine low on the front window in an attempt to make it more visible to the easy pass reader, just above the dash, it works every time.
07-06-2018, 10:40 PM
Blog: RVroadtripper.com
We live in Texas and bought our EZ Pass through Virginia website. They required me to get 2, the blue one is for when I'm towing the 5er and it's good for 4 axles (2 truck, 2 trailer). The white one is 2 axles (ie truck when we are not towing). We put the white out when we're sightseeing. They send a foil pouch to insert the not being used one in. Initial charge is $35 each but the total $70 goes into a single account that registers tolls from both transponders. Virginia does not charge a fee or deposit for the transponders unless you fail to send them back when or if you close your account. Also Virginia has no minimum monthly charge for any months that you don't use them. Lastly, you can pre-buy them even if you live in another state. Perfect for us RVers that travel to EZ Pass states in-frequently.
Maxxis 235/80/16E; AirBags w/AirLift1; mor/Ryde Rubber Pinbox; Andersen UltimateII Alum. 5erhitch on Reese Flipball w/Curt 4" offset; LCI Ground Control3; King Dishtailgater; Traveling with 10' Portabote;
07-14-2018, 06:28 AM
I sent my windshield mount one back for a license plate mount flavor. I was getting some misreads.
2019 Jayco Greyhawk 29MV
2019 F-150 3.5 EB SCREW Max Tow - 1797 payload
07-19-2018, 08:49 PM
Professional Tinkerer
I opted for license plate mount. Had issues with my windshield mount on my Jeep because of a light bar... didn’t want to take any chances.
On a side note, I opted for an NC Quickpass, which works on almost everywhere in the Eastern Coast. It covers EZPass, Peach Pass and SunPass in FL. Just another option to consider!
2018 Sunseeker 3270...
...sleeps 4 (2 adults, 2 kitties)
07-19-2018, 08:51 PM
X2
2015 Solera 24r
2017 Jeep Wrangler
07-20-2018, 08:09 PM
we put ours toward the front of the dashboard, and we have been traveling across the country without any trouble.
