Originally Posted by Steeljag
Anyway, the OPs question was in regards to info on where he could get his oil changed at a reasonable cost !
And my answer as others is the best place to get oil changed at the best place is at home!
All he needs is a Fumoto valve with a drain hose option and he can do the oil change in his church clothes using a creeper.
Make sure you use a Ford spec oil. If you take your Ford diesel to a non-Ford shop, I'm 99% sure they will not use an oil that meets Ford specs. There are very few API CK oils that meet the specs. API CK came out last Fall. If you use a CK oil it must have this spec on the label: WSS-M2C171-F1
https://go.chevronlubricants.com/rs/...SWUydUk9In0%3D
BTW, most Ford dealers will use a 10w30 oil in your diesel. If you tow, 5w40 or 15w40 summer months is what is recommended. I personally prefer 5w40.
I'm posting this not to give the OP a hard time but be aware that going to a non Ford oil change shop does not gurantee you will get the right oil. Ford discovered that many API CK oils DO NOT provide sufficient engine wear protection. I suspect that is due to API CK oils having less anti-wear additives such as ZDDP to protect emissions DEF at expense of engine....gotta love the EPA!
