Old 09-06-2018, 06:30 PM   #21
Originally Posted by KyDan View Post
This subject is going to be controversial as opinions will vary and everyone thinks their way is the best/only way to handle it but.....
IMO it's best to either let the engine run until it reaches operating temp or don't run it at all. Donno where you store but if it's cold and you start it - there will be condensation in the engine and in the exhaust that probably won't be eliminated by a short engine run.
My 2 ¢
Happy Trails!
Right, according to the Ford owners manual: Every 15 days move at least 25', run for a minimum of 15 minutes at fast idle set to defrost until reaching normal operating temperature. With foot on brake shift through all gears.
Kim
bayoubelle is offline   Reply With Quote
Old 09-07-2018, 09:37 AM   #22
Wolverine 1945's Avatar
Originally Posted by Shredder View Post
For the genny I also and make sure to run it long enough to get the gas with the stabalizer in the float bowl and then for it till it stalls. 2 years now starts right up next season and still runs strong but i run it hard at startup and let it run for 30 mins or so.
So you are able to run iy out of fuel ???
Wolverine 1945 is offline   Reply With Quote
Old 09-08-2018, 06:25 AM   #23
texasblues's Avatar
Thanks for your replies.
texasblues is offline   Reply With Quote
propane, winter
