Old 05-04-2018, 02:13 PM   #21
RedLdr1's Avatar
Originally Posted by tonyz1 View Post
Great rig. Wish you the best camping adventures with it. One thought about the winterizing and pump issue, I installed a toggle switch near the water pump so I could winterize by myself. Before I put in the switch, I would pull the small inline fuse that is located next to pump but that got old quick. Anyway, just a thought.
Installing a switch is a very good idea...
Wayne
2022 R-Pod RP-192
2021 F-150 4X2 SuperCrew Lariat 502A, 3.5L Powerboost Hybrid, 3.55 gears, 7.2KW Pro Power, 1,840# Cargo, 7,000# Tow
It is better to have too much truck than to have too much trailer.
RedLdr1 is offline   Reply With Quote
Old 05-05-2018, 08:02 AM   #22
Wolverine 1945's Avatar
Originally Posted by A32Deuce View Post
You dont use that much' Im still on my first container, about half since 2013.
I kind like the idea I can smell it,,,
then I know when I have removed most of it !!!
We once bought a bleach that did not smell like bleach,,,
It is around here some where,,, will never get used in the MH !!!
Wolverine 1945 is offline   Reply With Quote
Old 05-05-2018, 08:15 AM   #23
I have always used a couple of boxes of baking soda. Mix it with some water and put in in the tank. Pump through the system, let it sit for an hour and then flush the tank and system with fresh water. Sanitizes but leaves the tanks and everything with no smell at all.
When I did this with cruising boats, there were those who went out and got a big bottle of cheap vodka....
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 05-05-2018, 08:20 AM   #24
I like the Vodka idea !!!
Baking Soda does not sanitize does it ???
Old 05-05-2018, 08:25 AM   #25
You are correct. I will, however, remove any taste and smell from the system and clean the lines of most particulate.
2015 335DS
Old 05-05-2018, 08:45 AM   #26
So flush with Bleach or Vodka first,,,
Then with Baking Soda,,,
And you are better than new !!!
first time, winter
