Old 05-17-2024, 03:50 PM   #1
Ford E450 2012 A/C not blowing right
We have a 2012 Forester. The A/C is Just blows out the defrost and floor vents. So we must have a vacuum leak. We pulled the red vacuum line on the passenger side under the hood by the battery apart. One end has good vacuum from the engine, the other end when sucked on has no restrictions when blow into must have a check valve as no air can be put in by mouth.
I have a smoke machine and want to interduce smoke into the system. I think I need to find this check valve and bypass it to get smoke into the system to find the leak.
How do I get access to this valve?
Is there another way to get smoke into the system?
Harley Bob is offline   Reply With Quote
Old 05-17-2024, 08:10 PM   #2
The vacuum line runs down behind the heater box to a vacuum ball. From there it runs up inside to the panel on the top of the dash.
I just bought a few feet of vacuum line, a check valve and ran the line, from the fitting near the engine, into the cab thru the antenna grommet, to the original line just above the passengers feet.
Twinboat is offline   Reply With Quote
Old 05-18-2024, 10:27 AM   #3
Thanks for your reply. where is the check valve and vacuum ball, is it in the cab or under the hood? How do you get to them?
Old 05-18-2024, 12:21 PM   #4
Remove the fender. That's why I by-passed it.
Old 05-18-2024, 08:25 PM   #5
RVrover's Avatar
Bypass
This is what I did. See here and here and watch the video below. Hope this answers your question.
Osama - RVrover
2018 Sunseeker 3010DS
Like a short skirt, a useful conversation is short enough to retain interest and long enough to cover the subject.
RVrover is offline   Reply With Quote
2012, e450, ford
