Originally Posted by Patten
Has anyone with the stock Ford OEM TPMS system found a solid dually valve stem/extension kit? By solid, meaning not braided, composite or rubber. I took my 2021 3051 (Ford E-450) to a reputable RV Wheel/Alignment shop here and they were stumped by the factory TPMS system. These guys have been around for a long time and are consistently busy. They performed my alignment and agreed with everything in the sticky at the top of our section regarding alignments. So it kinda surprised me that they were stumped. Apparently I was their first Class-C with OEM TPMS that was external to the tire. If so, any guidance or links would be appreciated. Thanks in advance.
Safe travels and Happy Camping,
Mike
Not sure what the confusion is with the OEM TPMS, but if all you're looking for is bolt in (metal - brass with chrome plating) duallyvalve.com has them for you.
Call them, they are very knowledgeable about what your specific fitment needs to be or can help you figure it out.
https://yourtireshopsupply.com/categ...lly-valve-kits
Inners, 8" long shown below. Outers in the kit are 135 degrees and the fronts, which I purchased separately from them, are 2.25" long prebent at 20 degrees.
If you've got aluminum rims might not need the fronts. Those of us with beauty rings need the fronts most likely.
