Old 03-03-2018, 06:30 PM   #1
Forester 2861DS low point
We recently purchased a 2018 Forester 2861DS and I can only find a hot water low point drain and fresh water tank drain. Since my other MHs had both hot and cold water low point drains I'm wondering if I am missing something and if there's only one how does the cold water lines drain.
Freelander is offline   Reply With Quote
Old 03-03-2018, 06:35 PM   #2
sgtlm17's Avatar
Your low point drain is one red pex below rig. It is designed to be used when the water heater is in bypass mode making the cold and hot water lines all connected.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 03-03-2018, 06:35 PM   #3
A32Deuce's Avatar
Mine drain into the gray tank. Capped for the hot water and a valve to open to drain the fresh water tank.
A32Deuce is offline   Reply With Quote
Old 03-03-2018, 06:46 PM   #4
Thank you sgtlm17 for the super fast response!
Old 03-04-2018, 05:13 PM   #5
My 2860ds there is a low point drain right next to the hot water drain below the water pump and filter. The valve is in the pump compartment. I plan on adding a valve to the hot water line in the same spot.
2018 sunseeker 2860DS
ACJC is offline   Reply With Quote
Old 03-04-2018, 05:39 PM   #6
Certified Curmudgeon
Duckogram's Avatar
I have the same setup however I am under the impression that the valve you speak of is the fresh water tank drain and not a low point drain for your plumbing. i.e. ditto to what sgtlm17 said.
Welcome to Lake Wobegon where Justin and David utilize abductive reasoning to help solve F/SS issues.
Happy Trails and Remember the Pequod.
forester
