Originally Posted by Joerunr
The Rear Stabilizers! What good are these things, are they really needed? We don’t run a dance floor in our coach, and the passenger side one doesn’t extend or retract, we have to crank it up and down with a socket wrench. Any thoughts on the one that doesn't work?
If you’re satisfied living in the coach without the stabilizers down, why not just remove them? The MBS could probably benefit from any weight savings.
If these are electrically operated, the one that doesn’t work probably has a bad switch, disconnected wiring, or a bad motor.
