Old 09-29-2022, 03:21 PM   #1
Fresh water Drain where is it!!!??
OK I am having the same problem I cannot locate the fresh water drain valve.
I have bad water in my system and we are camping and I need to drain it as soon as possible!!
Been crawling around on my back been looking for over an hour.
thanks.
2016 Sunseeker MBS
azmotoman is offline   Reply With Quote
Old 09-29-2022, 05:21 PM   #2
You've got a motorhome and it's possible that the valve is in the wet bay with all the other plumbing. If there is no valve beneath the fresh water tank, look for a valve (someone's had a blue handle) in the wet bay.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 09-29-2022, 06:06 PM   #3
I haave a 2019 Sunseeker MBS and the fresh drain i located in a compartment with the low point drains.
rgt3000 is offline   Reply With Quote
Old 10-01-2022, 03:14 PM   #4
TomAR's Avatar
What model Sunseeker MBS?
Mine (MBS 2400R) has low point drains in TWO locations.
One is in the wet bay compartment, in the secondary hatch where the water pump is located. This is a 1/4 turn valve.
Another is/are(?) the hot and cold drains beneath the kitchen sink area - outside just aft of the retractable step. These are twist-on caps on red and blue PEX tubing.
2018 Sunseeker 2400R MBS (w/dinette)
2013 Honda CR-V toad
TomAR is offline   Reply With Quote
Old 10-02-2022, 08:40 AM   #5
JWallet's Avatar
thanks.
2016 Sunseeker MBS
My 2020 Sunseeker drain is located on the passenger side compartment directly behind the rear wheels. Inside the compartment is a latch to open the access to the water filter and drain valve.
JWallet is online now   Reply With Quote
drain, fresh water, water
