Originally Posted by Duckogram
emm-dee’s mod is convenient but consider that it may have a few issues. Not that it will, just that it could.
1. It puts water outside of the heated compartment. So if you camp in sub freezing conditions it could freeze and break the pipe or valve and then you can have a skating rink for a patio.
2. It may be susceptible for road debris impact. A tire tread (hopefully not yours) could take it out. You probably would not know till you try to flush.
3. Amokians. Ya just never know. They are very fast and easily amused. Just sayin.
YMMV
1...It’s called a drain valve. When open all the water leaves so there is nothing to freeze.
2...Look closely at where the line/valve is located behind the flap at the rear wheels and behind the exhaust pipe. If something gets past those to damage the drain line I wouldn’t be concerned about replacing $3 worth of drain compared to the cost of the other damage.
