Old 09-11-2016, 06:44 PM   #1
Front Cap Inspection
So with a lot of folks experiencing leaks in the front cap, I decided to do a complete inspection this weekend.
I purchased my 3010ds in 2012 and it is stored undercover.
The first time the roof was inspected was on vacation in Colorado in 2013. We went through a horrible storm on the way out to Colorado in Kansas from Ohio.
I did not look for leaks then. But we did find cracks in the dicor on the passenger side of the coach along the cap seem and sealed them then. I never checked the inside for leaks.
We have been to Maine, Hilton Head, Gatlinburg, Upper Michigan a few times, 1000 islands area and many other outings.
I inspected the roof at the 1000 islands KOA a few weeks ago and laid down a tube of dicor on cracks on both the front and rear caps.
This weekend we were at Hocking Hills in Ohio had a hard storm so my wife and I throughly inspected the front for leaks and hurrah! Found none.
However, we did find evidence of an old leak on the passenger side. The bed had about an 8 or 10 inch spot at the corner and the side wall had some minor bubbling. The bubbling was not soft, all hard and dry.
I'm going to reseal the marker lights in a week or two.
Anyway, I feel lucky cause I opted for the undercover storage. I think this would have been worse if it had been sitting outside.
I may eterna bond the seams next year. I recommend everyone do regular inspections of these areas in the roof. I think it's a very good roof but the design is weak at the cap interfaces.
Mike
MikeRP is offline   Reply With Quote
Old 09-26-2016, 10:00 PM   #2
Boso's Avatar
Front cap lights and above the window frames need to be checked on a regular basis
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 09-28-2016, 11:14 AM   #3
What sealant is best to use around lights and windows?
rekwiat is offline   Reply With Quote
Old 10-10-2016, 12:19 AM   #4
benagi's Avatar
What is the best way to seal the marker lights on the front cap. I was on the roof today and doing some preventive maintainence and decided to check the marker lights. The little silver ring that covers the grommet was loose on 3 out of 5 lights. Is that anything to worry about. It seems the grommet that hold the lights in should seal enough. It sure is a small tight space with work on if you are going to add a sealant and still make it look good.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
