Old 11-19-2017, 05:55 PM   #1
Front orange marker lights????
Does anyone know where to buy the orange front marker lights? I want to upgrade to LED and can't find them in the same shape???
Thanks for your time and reply!!!
kitejunky1 is offline   Reply With Quote
Old 11-19-2017, 06:16 PM   #2
Darmo15's Avatar
I have been looking for them myself. Have not found anything close.
Daryl
2014 Georgetown 351ds
Darmo15 is offline   Reply With Quote
Old 11-19-2017, 07:05 PM   #3
I will take one down and see who makes it. Try to contact the manufacturer
Old 11-19-2017, 07:07 PM   #4
Handyman
Try ETrailer
https://www.etrailer.com/dept-pg-Tra...ce_Lights.aspx
2016 Salem Cruise Lite 253RLXL
2013 F-150 XLT 5.0 Crew Cab
2009 F-150 King Ranch 5.4 Crew Cab
tfmdgm is offline   Reply With Quote
Old 11-19-2017, 07:11 PM   #5
acadianbob's Avatar
It there a bulb replacement?
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
Old 11-19-2017, 07:16 PM   #6
I have a crack in the lens, so i need the whole thing.
Old 11-20-2017, 07:21 AM   #7
Front Running Lights
I shared this issue last year. I lost one of the lenses on a trip to the Canadian Rockies. Upon our return, I assumed it would be no big deal and locate one online or from my dealer to replace it. To my surprise, the manufacturer of the lights went out of business. I was not able to find them ANYWHERE!. I contacted several suppliers found online and worked with my dealer with no luck. Someone did forward me an eBay vendor that stated he had them, but only had red lenses remaining. I worked with my dealer here in MN and we decided to replace all of the front lights with a chrome LED alternative. Unfortunately my struggle went from just trying to acquire one simple lense to replacing all of the front lights. Good luck.
Sunseeker 2900
BigB44 is offline   Reply With Quote
Old 11-20-2017, 08:58 AM   #8
Hello
Got mine from a Winnebago dealer in Illinois.
I will try to find the name and post it.
2014 SUNSEEKER 3010DS
TOADS, 2012 FOCUS OR 1998 JEEP WRANGLER,
Kevin & Judy is offline   Reply With Quote
Old 11-20-2017, 09:03 AM   #9
Flybob's Avatar
For some reason finding replacements ( especially LED upgrades) for many RV driving lights is a difficult task. I have had the best luck purchasing slightly larger LED replacements and replacing the entire fixture. Not only do they look great, but you can attach/seal them correctly and eliminate future problems.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-20-2017, 09:13 AM   #10
KyDan's Avatar
X2 I found signs of leakage on about half of the marker lights on my previous RockWood Ultra Lite.
If you're going to have to change out the entire fixture then it's the perfect time to change and properly seal them all!!
Peace!
Dan & Rita D
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32, 2020-41, 2021-49, 2022-43
Old 11-20-2017, 02:02 PM   #11
hkreck's Avatar
Pic of the types of lights might help. I had to replace my clearance lights all together because the company that made them is no longer in business. I have a 2013 FR Solera.
Henry & Tena
hkreck is offline   Reply With Quote
Old 11-20-2017, 03:39 PM   #12
I got my led lights from northern tool. Many auto parts stores and camper supply stores also have them. Much easier to find the assembly than the lens. They are easy to change, just remember that leds are polarity sensitive. Connect the wires and test before you screw them down.
2018 Forest River Wildwood 5th Wheel
2011. RAM 2500 Diesel Standard Cab 2Wheel drive
US Army Retired
Alleyantique is offline   Reply With Quote
Old 11-20-2017, 03:48 PM   #13
Old 11-20-2017, 06:25 PM   #14
hkreck's Avatar
Those look like the ones I had and as I stated I had to replace them completely because as I was told the company went out of business. I looked every where for them including on the internet but no luck. I went with a LED button style which took a little work to install but they look great on it now. You can see pic of it on forum (front clearance lights). It also has information about the old lights in the topic. Good Luck.
Henry & Tena
Old 11-20-2017, 06:41 PM   #15
2014 SunSeeker 2300
Awilson's Avatar
I had to buy a cutting board and shape it fit in the recessed area, seal it up and install the new light on it.
. We are now retired and living the dream! 2014 2300 SunSeeker without slides that we remodeled inside for better living conditions for two people.
Awilson is offline   Reply With Quote
Old 11-20-2017, 06:57 PM   #16
SecretSquirrel's Avatar
Don't forget to try checking at your local truck stop. The big rigs often have the same styles of marker lights. Most I've been at have a pretty good selection so they must need replacing often enough for them to stock them.
_________________________
Crusader 337QBH
2019 F350 6.7L DRW CC LB 4x4 Lariat
B&W Companion 20K for OEM pucks.
SecretSquirrel is offline   Reply With Quote
Old 11-20-2017, 07:15 PM   #17
davidjb's Avatar
Superbright LEDs has alot of different types
davidjb is offline   Reply With Quote
Old 11-20-2017, 07:16 PM   #18
Try starting here:
https://www.google.com/search?q=rv+c...w=1517&bih=750
2011 Traverse LT, 3.6L, FWD
Old 11-21-2017, 03:36 PM   #19
So how do you remove the marker lights on the top of the front cab? I looked briefly at them once and didn't see how it is done. I really want to make sure they don't leak.
2021 Micro Lite 25FKBS
2021 Ford F-250 XLT CCSB 4wd w/ 6.2l and 6 sp. transmission, 3.73 locking axle
gmacklem is offline   Reply With Quote
Old 11-21-2017, 04:07 PM   #20
grumpy0374's Avatar
Lots of lighting companies make rv/clearence/led lighting...
Diamond Lighting
Bargman
Made In The USA Lighting
Peterson Lighting
Grote
Probably more out there under trucking lighting and equipment.
Also, if you google up "oval clearence lights", many sights come up, and a lot of pics of whats available.
As for removing the lenses/lights themselves...
Almost all the lenses will pop off. Use a small thin bladed screwdriver..usually there is an indent or very small notch that is used to pry the lens off.
The base of the light is then attached to the body by, usually, two screws.
Take the base off, and you will almost always find 3 holes, two for the screws, and one for the wireing. To make sure they don't leak, simply put a dab of caulk over each hole and re-attach the bases. Did that to all 10 of my lights 5 years ago, using some Dicor. Still water tight.
Grumpy
Steve & Cheryl + Zoey, and Ziggy, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
grumpy0374 is offline   Reply With Quote
light
