Old 02-13-2019, 09:47 AM   #1
texasblues's Avatar
Furnace Air Filter
Does a 2015 Sunseeker 2800 QS have a furnace air return filter? If so, where is it located and how to get to it to clean/replace?
texasblues is offline   Reply With Quote
Old 02-13-2019, 09:54 AM   #2
A32Deuce's Avatar
No.
A32Deuce is offline   Reply With Quote
Old 02-13-2019, 09:54 AM   #3
Mr. Dan's Avatar
I don't know what type of furnace you have and I know I don't have the same unit as you do... but my furnace has NO return air filter and I've many others on here saying they don't have one.
Old 02-13-2019, 10:10 AM   #4
Kanadian Kamper
kenandterry's Avatar
I don’t believe the RV industry believes in furnace filter designs.....
So just sit back and breathe deep.
Ken and Terry
kenandterry is offline   Reply With Quote
Old 02-13-2019, 10:13 AM   #5
texasblues's Avatar
OK, thanks for the response
Old 02-13-2019, 05:03 PM   #6
A32Deuce's Avatar
It has to do with air flow, that's why no filter. How often do you remember to change the one at home?
Old 02-14-2019, 08:45 PM   #7
Garrette's Avatar
I have looked for a residential filter register but no luck. If you come up with something, please share.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 02-16-2019, 02:06 PM   #8
Senior Members
Butch & Lena's Avatar
I have an electric filter pad at home that I take out and clean every 2 months. It catches everything.
2015 3010DS Sunseeker
2010 Jeep Wrangler Unlimited
Butch & Lena is offline   Reply With Quote
Old 02-16-2019, 02:22 PM   #9
Every month.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 02-16-2019, 02:23 PM   #10
Just as confused as you
Scrapper's Avatar
If you install a filter on your rv furnace cold air return you will have reduced volume of return air. It could cause your furnace to overheat, cycle on/off frequently, or run continuously trying to reach the thermostat's set temperature. The return grill would need to be enlarged to compensate for the reduced air flow.
Richard & Jill
Old 02-16-2019, 02:32 PM   #11
Scrapper's Avatar
Never, I have hot water radiant heat. My bathroom is heated by the water routed in the rim of the bathtub. Put my feet on the tub rim when they're cold in early morning.
DW wants a different tub, I had to explain why it would be an expensive job.
Richard & Jill
Old 02-16-2019, 03:11 PM   #12
A32Deuce's Avatar
This was just a statement! Not at all looking for answers simply that an RV heater is different then your home and may/could cause an aid flow problem with the RV heater.
furnace, saunseeker, sunseeker
