Old 11-04-2014, 08:02 PM   #1
Furnace troubles
Been camping 5 months, so first time in cold weather. As we were backing in, our neighbor said he'd sold an identical rig. So, he helped us with the furnace.
However, it runs for about 5 minutes and cuts off. If I flip on/off it will restart, but always stops in 5 minutes
rlchall is offline   Reply With Quote
Old 11-04-2014, 08:20 PM   #2
Average Joe
MrJoe's Avatar
Does it blow hot or cold for 5 minutes?
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 11-04-2014, 08:30 PM   #3
VinceU's Avatar
Sounds like its tripping an overheat sensor. That can be due to poor gas flow through the heater/part blocked. Or poor combustion causing overheating, or even a bad sensor with false reading. Might be good to have it checked and repaired soonest. You don't want to overheat anything for real.
Old 11-04-2014, 08:36 PM   #4
It blows cold air.
Old 11-04-2014, 08:38 PM   #5
Average Joe
MrJoe's Avatar
Is there propane in the tank and is it turned on?
Joe and Karen
Old 11-04-2014, 09:44 PM   #6
Yes and yes. Our competent neighbor helped us with that part.
Old 11-05-2014, 07:57 PM   #7
wesslvm's Avatar
With previous camper I had to blow out nozzle to clear teeny spider nests. Worked like a champ. Spiders are drawn to propane for some reason!
2014 Sunseeker 3050S
Honda CRV (TOAD)
wesslvm is offline   Reply With Quote
Old 11-05-2014, 08:26 PM   #8
FWIW: had an issue with the furnace too--
Things to check:
low voltage
flame burning unclean-- yellow vs blue
clogged output or input (stuff in your tubes )
bad limit switch, or wrong one (I replaced 2 so far)
and finally, never been cleaned.
may be other issues not discovered.
traveler2955 is offline   Reply With Quote
Old 11-06-2014, 08:20 PM   #9
We will check out these ideas now that we're home. Love our new online camping community! ! You all rock!!
furnace
