Storage
Since you are talking about exercising the genset I must conclude that you are not out glamping. Common practice is to turn off the propane at the tank when the unit is not in use. Sooooo, if you had the gas off and subsequently turned it on to “test” the furnace, it is very possible that it took two startup attempts in order to purge the line and supply gas to the furnace. You can encounter that same situation with your fridge, water heater and cooktop.
Mike Dropped
