Old 02-08-2018, 07:55 PM   #1
Frankie Z's Avatar
Furrion TV
Just purchased a new Sunseeker 3010DS. I was setting up the TV's for Air channels, and when I ran the scans, the bedroom TV, which has a brand name of "Continu-US" found about 3 times more channels than the living room TV, a Furrion. The Furrion could not find any of the major networks, ABC,CBS, etc. Any suggestions?
Frankie Z is offline   Reply With Quote
Old 02-08-2018, 08:00 PM   #2
sgtlm17's Avatar
Check your antenna connections on the furion TV. The antenna pulls in the channels so if one TV sees them all the the TV's should.
If your rig is new it's very likely that some connection is bad, not connected or the TV itself is not working properly. Good luck.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 02-08-2018, 08:34 PM   #3
RedLdr1's Avatar
Definitely check your connections. If that doesn't fix it, and there is nothing obvious, swap the TV's and see if the Furrion works better in the bedroom and if the "Continu-US" has problems in the living room. Then you will know if it is the wiring or TV that needs to be looked at closer.
Wayne
2022 R-Pod RP-192
2021 F-150 4X2 SuperCrew Lariat 502A, 3.5L Powerboost Hybrid, 3.55 gears, 7.2KW Pro Power, 1,840# Cargo, 7,000# Tow
It is better to have too much truck than to have too much trailer.
RedLdr1 is offline   Reply With Quote
