Old 09-19-2020, 07:59 AM   #1
Do It Yourselfer
wuffwuff's Avatar
Fuse box on 3051
A friend is out in New Mexico and called me to find out where the fuse box was on his 2020 3051. Only thing he can find is the breakers. Are the fuses in that panel? His first trip out, says water pump doesn't work.
2022 Alpha Wolf 26RL-L
It's Easy to take 'Liberty' for granted, When you have never had it taken from You!
wuffwuff is offline   Reply With Quote
Old 09-19-2020, 08:46 AM   #2
Mr. Dan's Avatar
The water pump fuse is generally in line and within 18” of the pump - not in the fuse panel.
Old 09-19-2020, 08:48 AM   #3
Certified Curmudgeon
Fuzed
Yes and no. The 120v breakers and 12v breakers are in the same Progressive Dynamics power distribution box. There are fuses for the converter in there as well. The 12v breakers look like fuses but they have a little reset button in the middle of the side that faces out.
The water pump has its own fuse located near the water pump. Now your friend can tell you he/she does not know where that is.
Fuse is to the right of the pump in the photo. It is a 10 amp ATC fuse. Suggest not using an ATO fuse in that location.
Mike Dropped
Old 09-19-2020, 09:14 PM   #4
Do It Yourselfer
wuffwuff's Avatar
Help Appreciated
Thanks guys! Help me also... I didn't realize that where it was on my 3011dsf. Never had to look for it before. Just assumed it was in the PDS.
305, fuse
