Old 10-20-2015, 08:31 AM   #1
Fuse map for 2014 E450 - Blown fuse !
Is there a map/document that show what fuses are where in 2104 Sunseeker Ford E450?
My cigaretter lighters/ power sources are not working and I think it is because the fuse it blown.
I have found the fuse location but there is no cap or list that show what fuse belongs what accesory
Thanks !
2014 SunSeeker 3170DS
Ford F-450
drakethib is offline   Reply With Quote
Old 10-20-2015, 08:40 AM   #2
Total Loss's Avatar
Check your Ford manual or you may need to pull it off the internet.
It seems manufacturers are not stamping them into the fuse block cover anymore.
My 2013 Volkswagen had an electrical issue and I noticed that when checking the fuses. I asked the tech and he said that since the electronics are becoming so complicated, they do not want the average consumer poking around in there. He was kind enough to print one out for me since he figured I somewhat know what I am doing.
Just a sign of the times.
Total Loss is offline   Reply With Quote
Old 10-20-2015, 08:40 AM   #3
Class C Representative
Joshua Cavitt's Avatar
It should be written on the fuse cover. If not get a test light, it's 5 dollars at your nearest auto parts. Take the clamp and attach it to a ground, touch the point to the tiny metal pieces on the fuse, if it lights up then it's good if there is no light then it's bad. It's a great tool to have when trying to diagnose electrical issues.
PLEASE do not send questions via Profile comments or Private Message, my inbox fills up too quickly. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Joshua Cavitt is offline   Reply With Quote
Old 10-20-2015, 08:48 AM   #4
Thats part of the problem. There is no fuse cover.
Trying to avoid pulling 50 mini fuses to find the fault.
Ford F-450
Old 10-20-2015, 08:50 AM   #5
Who Dares, Wins
doc73's Avatar
Then the test light is the way to go. They also usually give you a cheap fuse puller /tester in the fuse replacement kits in the auto stores. They light up if the fuse is good and do jot if it is own. Just touch the two metal pins to the top of the contacts on the fuse while in place in the fuse box.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 Chevy HD D-Max
2022 Impression 315MB
doc73 is offline   Reply With Quote
Old 10-20-2015, 09:02 AM   #6
Just ordered this.
Still would hope I can find a map.
http://www.amazon.com/gp/product/B00...ilpage_o00_s00
Ford F-450
Old 10-20-2015, 09:10 AM   #7
Who Dares, Wins
doc73's Avatar
You have a 2014 f450 in your sig, but my guess is it is a E-450 if it is a sunseeker... Quick google search...
Page 187 is the fuse box area...
http://www.fordservicecontent.com/fo...us_10_2013.pdf
Incomplete chassis manual for 2014 e450's (since it is an RV would have been an incomplete chassis so this could be different)
https://www.fleet.ford.com/truckbbas...268-AA_IVM.pdf
2015 Chevy HD D-Max
Old 10-20-2015, 09:52 AM   #8
There are two fuse panels on the E450. One under the hood and one under the driver's side instrument panel. In some circuits, there’s a fuse and a relay, so if the fuse is good but you don't have power, check the relay. Many of the relays are the same so you can swap one that's good for one you need to test.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
Old 10-20-2015, 01:08 PM   #9
The one under the hood has a fuse map on the inside of the cover. This has most of your primary fuses.
j free is offline   Reply With Quote
Old 10-20-2015, 08:47 PM   #10
Here's a tip. The inside fuse panel has a number of fuse sockets that have no function, but there was a fuse in every socket. Therefore, there are lots of free spare fuses.
The underhood fuse panel has no unused fuses or relays. However, on one trip the fuse to the toad taillights blew, probably due to rain wetting the connector. I had no spare that size so I used the backup light fuse.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
Old 10-20-2015, 08:57 PM   #11
There's also a Ford Body Builders Layout Book that gives useful information.
https://www.fleet.ford.com/truckbbas...bodybuild.html
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
2014, fuse
