Old 06-04-2013, 07:32 AM   #1
Gasoline odor
Hey, does anyone else detect a slight raw gasoline odor outside the Onan Generator compartment after it had been running? Every time I walk past that compartment after I have been running it I get a whiff. I haven't seen any leaks... But it is worrisome. My unit has 8 hrs. On it now, and had the fuel pump replaced due to faulty part. Before we head on our 6k mile journey next week I want to make sure it's up to par!
4Gcampers is offline   Reply With Quote
Old 06-04-2013, 07:51 AM   #2
Fumes are common around some small engines after use. In your case I would check around the (Fuel Pump) lines. Youroo!!
Old 06-04-2013, 11:29 AM   #3
We used ours a lot on the last trip and didn't notice any gasoline fumes; but we were camped out in the open air. Still, we were close enough to the generator to note that like the truck engine, it bled a bit of water from the exhaust until it got warmed up. None of my little engines smell of gas unless I'm fueling them.
Geri is offline   Reply With Quote
Old 06-06-2014, 09:20 PM   #4
rbetzwieser's Avatar
Did you ever find the problem? I'm experiencing the same odor. It has me baffled.
Sent from my SCH-I545 using Forest River Forums mobile app
rbetzwieser is offline   Reply With Quote
Old 06-06-2014, 09:37 PM   #5
Plain Old Member
When we had ours, it was the same way after genset was shut off. Smell would eventually go away. Not sure if it was a problem or not.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 06-06-2014, 09:41 PM   #6
Hello again Big John! As far as the fuel odor, we still have it. However, I do think it's fuel pump related. Sadly, I'm on the 4th fuel pump with 52 hrs. on the gen set. It's already making some random ticking sounds, and the fuel odor, so I expect to get the 5th very soon, hopefully before the 2 yr. warranty expires.
Old 06-06-2014, 09:44 PM   #7
Also to clarify... All four of out pumps have gone out the same way. Fuel smell, then occasional ticking, then constant ticking, then dead all together.
Old 06-06-2014, 10:07 PM   #8
Great! I will keep listening for the ticking. I only have about 9 hours on the unit.
Old 06-06-2014, 11:08 PM   #9
Plain Old Member
Geez man. That would get old quick. I can't remember how many hours we had on ours when we sold it. I think it was close to 50 hours or so. At the time, I didn't know of any fuel pump issues like I read about now. It was still working then, but the guy that bought it may be cursing me now.
