Originally Posted by Bezzola
Has anyone installed or had installed a generator auto start that kicks in when the batteries get low. I only dry camp i have a 2012 forester class C with the one board onan.
My friends diesel push has it but thats a more expensive unit
I installed a Magnum MSH3012 inverter with AGS. I have it programmed to start at 40% SOC and shut off at 95% SOC. I also have some quiet time and load triggers set up. This is not inexpensive equipment, nor is it a simple install. I probably have 80+ man hours in the electrical system upgrade alone. There are simpler options if you only want AGS. You may have some trouble with these basic systems if you use Lithium batteries as these basic systems are going to rely on battery voltage to determine SOC which is inaccurate for Lithium systems.
2015 Sunseeker 2500TS
Magnum 3000VA Hybrid Inverter w/AGS, Relion Lithium w/Victron BMV-712, 600W 24V Solar, 5 Star tune, Hellwig Bars, Safe-T-Plus, Sumo springs, On-board SSD PLEX server, MOFI cellular router, Full HD video distribution w/Apple TV's...
IBEW Local 551 Foreman
