Old 04-23-2018, 07:12 AM   #1
Frankie Z's Avatar
GFI outlets
I have 5 GFI outlets 1 bathroom 2 kitchen 2in bedroom. Only bathroom has reset switch. Bathroom one works other 4 do not. I am assuming they are on same circuit since only one has reset switch. No breakers are tripped no fuses are marked i.e. bedroom outlet, kitchen outlets etc so before I start pulling fuses any suggestions.
Frankie Z is offline   Reply With Quote
Old 04-23-2018, 07:31 AM   #2
geezer with gadgets
757Dave's Avatar
Have you tried pushing the test button then the reset button on the gfi in bathroom? Also, this is all on the 120v circuitry. I don't believe that there are any fuses to deal with only circuit breakers.
Hopefully those with much greater knowledge will chime in with other suggestions.
Good luck!
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
2017 Jeep Grand Cherokee TOAD
Days camped 2015: 37; 2016: 66; 2017: 86 2018: 57 2019: 30
757Dave is offline   Reply With Quote
Old 04-23-2018, 07:44 AM   #3
Frankie Z's Avatar
I did try resetting the button no luck I want to add this is a brand new coach so maybe there something wrong with the wiring
Old 04-23-2018, 12:10 PM   #4
2014 SunSeeker 2300
Awilson's Avatar
Im not familiar with your coach but how do you know all the others are GFI? Is your breaker in the panel a GFI breaker? I assume you have a tester and are testing the power at the outlets and the breaker box. Iím sorry but my SIL isnít here and he is my electrician and Iíve gone up to and possibly surpassed my realm of knowledge.
Alan
. We are now retired and living the dream! 2014 2300 SunSeeker without slides that we remodeled inside for better living conditions for two people.
Awilson is offline   Reply With Quote
Old 04-23-2018, 12:17 PM   #5
Check for a GFI outlet on the outside of your rig. My TT had stickers on some of the interior outlets saying they were controlled by a GFI outlet. They were not GFI outlets themselves.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 04-23-2018, 01:14 PM   #6
Certified Curmudgeon
Duckogram's Avatar
Frankie Z,
Assuming your GFCI has power and the downstream outlets do not. That is an indication that you have a connection issue on the back side of the GFCI outlet. Easy check; Disconnect shore power/turn genset off. Turn off any inverter you may have. Remove the GFCI outlet and check the output connection.
Welcome to Lake Wobegon where Justin and David utilize abductive reasoning to help solve F/SS issues.
Happy Trails and Remember the Pequod.
Duckogram is online now   Reply With Quote
Old 04-23-2018, 02:42 PM   #7
Frankie Z's Avatar
Alan
They have stickers stating they are gfi protected
Old 04-23-2018, 02:58 PM   #8
Flybob's Avatar
Check for a second GFCI maybe outside.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-23-2018, 03:01 PM   #9
Go to your electric panel. Check all the 15 amp breakers. Turn each one off and back on. Since you stated you have a GFI in the bath I'm gonna guess you have no GFI breakers. You stated you have one it the bath. Does that one work? It will not reset if it is not tripped. test both buttons. 2 in the bedroom should not be on it but we are talking about RV wiring The bath GFI should also cover the kitchen counters and outside outlets.
Old 04-28-2018, 05:39 PM   #10
I had a plug-in that was not working. It turns out that it was downstream from another plug-in that had a poor connection on the rear of the plug-in. The plug-in had some type of push on spade system that slice the wire when itís pushed into the slot. A poor connection meant that all the rest of the plugs were dead. It was not GFI so I am not sure if this type of plug-in uses those spade system.
sask is offline   Reply With Quote
Old 04-28-2018, 05:54 PM   #11
Frankie Z's Avatar
Thanks to all who replied. I appreciate the time everyone took responding. Today I discovered it was a loose connection on the back of the GFI outlet that shut down the other outlets.
Old 04-28-2018, 05:56 PM   #12
good to know, and good that you found it
let's us all know what to look for when we have the same problem, and we probably eventually will : )
formerFR is offline   Reply With Quote
Old 04-28-2018, 05:56 PM   #13
Duckogram's Avatar
Glad you found it.
Old 04-28-2018, 06:04 PM   #14
Flybob's Avatar
If there is room in the box it is always best to replace the outlets with traditional outlets with screw type connections. The punch down outlets are quick to use, but as you found out not very reliable.
TST Tire Monitors
2 100W solar panels
