Originally Posted by Khawk
The brochure I received when on purchased my 2021 Sunseeker 2440DS states it is pre-wired for solar on the side in order to add additional solar panels. However I’m unable to locate the connection.
Thoughts?
On our early build 2020 24440DS, there is a “solar on the side” connector on the outside wall to the left (aft) of the coach entry door, below the exterior 120 volt outlets. It is just a two wire connector wired to the house battery. If I wanted solar power, I would need to supply a controller and panels.
We did not order any solar option with our unit, which has a propane/AC refrigerator. Since your 2021 likely came with a 12 volt refrigerator, yours may have included a roof solar panel. In that case the “solar on the side” might take on a new meaning or not exist.
I looked at a photo of a 2021 2440DS in the brochure, and the connector is not there. That means very little because the Sunseeker brochures are sloppily done and often contain many errors. To illustrate my point, that same 2021 brochure also shows a 2019 or an early build 2020 2440DS with a propane refrigerator, and the solar on the side connector can be seen.
https://www.forestriverinc.com/broch...erbrochure.pdf
