Old 04-22-2018, 03:34 PM   #1
Hoglou's Avatar
Good bye wheel simulators
Using TPMS with the wheel simulators for me was a pain. Fixed the rim scares (white primer was great match) and swapped to center caps.
Happy days..
Hoglou the DH & BK the DW (retired and happy)
WestGA KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 04-22-2018, 04:27 PM   #2
RedLdr1's Avatar
Looks really good!
Now if I can find nice center caps to fit a E-450 dually I'll join you in ditching the "wheel simulators"....
Wayne
2022 R-Pod RP-192
2021 F-150 4X2 SuperCrew Lariat 502A, 3.5L Powerboost Hybrid, 3.55 gears, 7.2KW Pro Power, 1,840# Cargo, 7,000# Tow
It is better to have too much truck than to have too much trailer.
RedLdr1 is offline   Reply With Quote
Old 04-22-2018, 04:27 PM   #3
I like that !
2019 Jayco Greyhawk 29MV
2019 F-150 3.5 EB SCREW Max Tow - 1797 payload
s1njin is offline   Reply With Quote
Old 04-22-2018, 04:39 PM   #4
Now a "Top Member"
EdJunior's Avatar
Okay, I'll bite. (Because I don't know) What are wheel simulators?
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Retired AF MSgt
Old 04-22-2018, 04:41 PM   #5
Hub caps?
Brewhedd is offline   Reply With Quote
Old 04-23-2018, 07:56 AM   #6
RedLdr1's Avatar
Originally Posted by Brewhedd View Post
Hub caps?
Over priced, over sized, over weight, full wheel "hub caps" that FR installs on most motor homes... They rattle, they block the valve stems, and the even come off and pass you occasionally... True junk...
See the attachment below.
Wayne
2022 R-Pod RP-192
Old 04-23-2018, 10:24 AM   #7
Total Loss's Avatar
I did something similar but went one step further.
Blacked out the wheels to match the black trim on the rig and added trim rings.
Ease of tire pressure adjustments is great now.
"If you are going through hell..keep going"
W. Churchill
Total Loss is offline   Reply With Quote
Old 04-23-2018, 12:01 PM   #8
Also used on Jayco and Winnies.
Old 04-23-2018, 01:28 PM   #9
Hoglou's Avatar
mash - adam's ribs
Trim rings, dang that would have saved me a lot scar fixen's. Reminds me of Hawkeye ordering ribs and forgette'n the cole slaw. Part number and source?
The centers are from hubcap heaven $170 delv.
C5125FS-CHEV Chevrolet 3500, 4500 DRW Front Silver OEM Center Cap #15053704
C5125RS-CHEV Chevrolet 3500, 4500 DRW Rear Silver OEM Center Cap #15053705
All the grey is brushed primer to fill in the scars. Sanded with 150, 220, then wet 500. Hay, it's what I had in the shop..
.. If you are ordering a new coach ask them to leave the wheel simulators inside the coach, you can then decide if you want'em. Do you want'em I got four to ship....
ID:	169333   Click image for larger version
Old 04-23-2018, 02:06 PM   #10
Good Bye Wheel Simulators
Hoglou, I ditched the simulators also. I assume you have duallys on the back axle. What air compressor brand, and where purchased, do you use to get the air hose on the valve stems that face toward the wheels? Very difficult to get air hose through the rim holes and onto the stems. Local tire dealer advised not to use valve stem extenders as they will break off from the rim. Most air hoses I've looked at are too stiff to get on the valve stem; they are not flexible or long enough to attach. Also what brand of TPMS (where purchased) are you using? I have a 2018 Coachmen Freelander Chevy 4500. Thanks Pat
thepeddler is offline   Reply With Quote
Old 04-23-2018, 02:27 PM   #11
re
I took my Forester to a truck tire repair and replace business and had inside and outside extended brass valve stems installed.
poppytoymaker is offline   Reply With Quote
Old 04-23-2018, 02:29 PM   #12
Hoglou's Avatar
tire time
TPMS is TST. On year three working well. On board air a Vair compessor. Being a chevy dually you may have steel stems, We do. For the inside rear I have a TST flow thur tpms sensor on factory nylon extentsions. Looking for the rubber wheel plugs to hold a new set of steel extentsions or the inside tires but after 20m miles no issues with the flex. They are covered with 3/8 wire covers from harbor frgt for $3 and a little elect tape to prevent chaffing.
On the outward dually I have a j hook extentsion with a screw on tmps sensor.
ID:	169340   Click image for larger version
Old 04-23-2018, 02:59 PM   #13
poppytoymaker and hoglou: thanks for the quick responses...I will take a look at my tires and rims to see if what you both do works. Pat the peddler
Old 04-23-2018, 04:24 PM   #14
Mtnman64's Avatar
I have wire tied the crap out of theses things, and they still slip. FR needs a solution cause I paid extra for those things !!
Mtnman64 is offline   Reply With Quote
Old 04-23-2018, 04:32 PM   #15
2007 WildCat 32QBBS
18CrewDually's Avatar
If any of you guys are sitting on a pair of rear 16" Ford/Dodge & will part with them, PM me with your price. I need 2 sets for my flatbed gooseneck trailer but can't see paying so much for new ones.
Thanks for any responses.
18CrewDually is offline   Reply With Quote
Old 04-23-2018, 05:48 PM   #16
Now a "Top Member"
EdJunior's Avatar
Ah, gotcha. I am now learned. Thanks.
Ed and Sharon
2010 Wildcat 28RKBS
Retired AF MSgt
Old 04-23-2018, 05:53 PM   #17
amblt's Avatar
Hub caps?
My dad hated hearing wheel covers and other such decorations "hub caps". He insisted that hub caps are the little covers we pull off to get at the bearings.
Cheers
amblt is offline   Reply With Quote
Old 04-24-2018, 11:59 AM   #18
Truck System Technologies Rep
TST TPMS
Hello,
If you have any questions on the TST TPMS mentioned in the thread above. Feel free to contact me at 210-420-0132 anytime.
Thanks,
Mike Benson
TST TPMS
210-420-0132
mbenson1234 is offline   Reply With Quote
Old 04-24-2018, 12:02 PM   #19
There are more issues with these "wheel covers".
I had a set of custom valve extenders installed, because the wheel covers made it so hard to fill the tires.
Then, I noticed just in time that the wheel cover had slipped, and had worn a groove into the valve extender. Had to have a new valve extender installed, and I glued a rubber grommet into the hole to protect the valve extender, and watch it very carefully.
Shortly thereafter, one of the wheel covers fell off.
Very poorly made.
jeffrapp is offline   Reply With Quote
Old 04-24-2018, 04:59 PM   #20
Hoglou's Avatar
poppytoymaker
Poppytoymaker, got a pic and part num?
wheel
