09-11-2017, 10:03 PM
GPS too quiet on 3010
Hello fellow RVers!
Our issue is that when the radio is on, the GPS is too quiet to hear. If I turn the GPS volume up to an understandable volume, the radio has to be blasting. So, needless to say, we haven't been able to use the GPS.
Thank you very much for your help!
Sancia
09-11-2017, 10:05 PM
In your settings you set the levels. So set your radio to say 3 then GPS to 5.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
09-11-2017, 10:25 PM
Thank you so much for your answer! Safe Travels!
09-12-2017, 11:24 AM
DW's 401(k) Plan
Originally Posted by SeaDiver
Hello fellow RVers!
Sancia
Your GPS actually works????? 😮.
Mine has given me an error indication since day one. I just haven't had any need to use it yet, or I would have raised a ruckus with the dealer.
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
09-12-2017, 07:21 PM
My gps works great, radio doesn't work have to use cd and that is the pits!
09-13-2017, 06:34 AM
Raise the ruckus now while you still have the warranty. Otherwise, by the time you need it the warranty will be over and YOU will be stuck holding the proverbial bag!
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
09-13-2017, 07:04 AM
I would have it checked by your dealer.My 2017 3010, I'm on my third radio. The radio plays but after a few minutes the volume shuts off then comes back on . The gps was doing the same thing.
09-14-2017, 07:48 AM
Right On Mike,,, thanks to the little radio antenna being under the nose,,, the radio is almost worthless !!!
09-14-2017, 07:54 AM
Wouldn't it have been nice if FR would have wired the radio to the antenna on the roof !!!
09-14-2017, 11:43 AM
GPS
I posted, I think, a question about GPS's. I have a Rand McNally trip maker. Fixed once and now problems again. Any recommendations for a GOOD replacement? I drive a 2017, 30', Sunseeker. Thanks
09-14-2017, 11:35 PM
Your GPS actually works????? .
Thank you! After reading your post, I remembered that 'No', it is not dependable. The last trip we were on, it froze several times. Nothing worked except turning it all off for a while and restarting. Glad we have our phones.
SeaDiver
09-14-2017, 11:38 PM
We had issues with GPS freezing also, along with the volume problems. Cheap, cheap, cheap! But still love the 3010DS!
SeaDiver
09-15-2017, 03:51 AM
My gps is quite too as of today. It is also my radio and bluetooth to my phone.
Apparently its volume something or other inside went out because now the GPS works but NO sound for even the radio
09-15-2017, 08:00 AM
I believe Jensen makes a dash mount unit,,, but I know nothing about it !!!
FR was going to replace my Magnadyne with a Jensen,,,
but did not have the right wiring harness ???
09-16-2017, 12:11 AM
We have the Jensen that came with our 2016 Forester 3171 E450 Ford . Works fine.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
09-16-2017, 08:22 AM
Does your radio work well ???
Do you know if it is connected to the Ford antenna ???
Does your Forester have a nose that covers the antenna ???
09-16-2017, 11:46 PM
Yes, yes, and yes.
1968 tent trailer
1985 Jamboree 23 ft
09-17-2017, 09:29 AM
Yes, yes, and yes.
That is great,,, ours works soooo bad we do not use it !!!
I was trying to listen to a football game last Saturday on the hwy,,, I had to change stations 4 times in about 60 miles !!!
IT SUCKS !!!
09-17-2017, 11:52 PM
IT SUCKS !!!
I have to admit, when we get 30 miles give or take from a station we are listening to, we also need to search for a stronger station.
1968 tent trailer
1985 Jamboree 23 ft
09-18-2017, 05:00 AM
There is a solution to that...............XM Radio
