Old 06-04-2023, 08:16 PM   #1
GRATEFUL
GRATEFUL TO BE ALIVE�� I own a 2005 forest forester. I can only find 1 valve in my plumbing. It's not by the hot water heater. The only valve that I can find is closest to frest water tank which is located under master bed. There are Also, 2 slide outs. Now the problem is that I only get 3 to 4 seconds of hot water then runs cold. I made sure outside shower are off. Now the shower worked just fine about a week or 2 ago.???
Mfj319 is offline   Reply With Quote
Old 06-04-2023, 08:32 PM   #2
Mr. Dan's Avatar
Thread moved here from the Welcome Mat due to the technical nature of questions.
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 115/'22 = 135/'23 = 78; Booked for 2023 = 28
Old 06-05-2023, 07:27 AM   #3
Kanadian Kamper
kenandterry's Avatar
Welcome.
You need to provide a lot more info for our help for you…..
What make and model of Forester do you have?
What make and model of water heater do you have?
Is this a new to you motorhome, because knowing where and how to position the water heater valves is key to resolving your troubles.
What did you do with your rig between the times when it worked fine until now?
Ken and Terry
kenandterry is offline   Reply With Quote
