Old 09-04-2017, 06:07 PM   #1
Gray water won't drain
We have a 2014 Sunseeker. Our gray water tank won't drain.
What should I look for?
Thanks!
cheechcat is offline   Reply With Quote
Old 09-04-2017, 06:21 PM   #2
sgtlm17's Avatar
Try a snake up the drain pipe. Many users report blockage by debris when rig was built. Such as the round circle piece of plastic that may drop in the tank when they install the tank
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 09-04-2017, 06:37 PM   #3
Mr. Dan's Avatar
Not even a drizzle =====> cable which operates the valve might have come loose from the valve. Yep, happened to me.
Getting at least a trickle =====> maybe a scrap of plastic/wood finally floated down and plugged the valve.
Another possibility ====> gray tank is empty or you're pulling the wrong valve.
That's all I've got without seeing your unit.
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 115/'22 = 40; Booked for 2022 = 70
Old 12-26-2017, 10:07 PM   #4
the factory is notorious for drilling the hole for the tanks and letting the cut out piece fall into the pipe. When mine was brand new the entire lower system had to be taken apart to remove the disc dropped down by the factory.
Sunseeker 88 is offline   Reply With Quote
Old 12-26-2017, 10:40 PM   #5
Mr. Dan's Avatar
I recommend we save our typing/suggestions/attempts to help.
For this OP ===> "Last Activity: 09-04-2017 09:52 PM"
Old 12-27-2017, 06:22 AM   #6
Guessing his grey tank is pretty full by now. LOL.
Rusty
lcv800 is offline   Reply With Quote
drain, water
