Old 08-11-2013, 04:01 PM   #1
NCIC105's Avatar
Heat Pump
This is the first unit I've owned with a heat pump. Is it just like a home's heat pump? Will it cool the unit or do you need to keep it in air conditioning position?
I've noticed it has both selections.
NCIC105 is offline   Reply With Quote
Old 08-11-2013, 04:39 PM   #2
Use the cool position for cooling and the heat pump position on the thermostat for heat. Just like home heat pumps, it will be effective at temps above freezing. Below that the furnace is better. Main advantage is using campground electricity instead of your propane for heat.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 08-11-2013, 05:36 PM   #3
semi-senior member
denandra2's Avatar
You can set your thermostat on auto and it will warm up on those chilly morns and cool late in the afternoon when you might need just a little cooling.Mine works like that but I mainly keep it on either heat or cool!
Happy Camping
Dennis & RuthAnn
Tippy too!
Columbus (2014)320RS
2014 Ram 3500 DRW 6.7HO
Aisin 6speed Auto
SE Mo
denandra2 is offline   Reply With Quote
pump
