Originally Posted by bbRN
Where are the valve controls/hoses for bypassing the hot water tank in a 3040DS? Also, how to drain hot water tank?
Before you drain the water heater, FIRST TURN OFF THE ELECTRICITY!!
If it's a Suburban, the switch is on the outside at lower left, hidden behind the air tube.
If you don't turn that switch (or the circuit breaker inside) off, you will burn out the electric heating element, a nuisance that will cost you about $11 plus $3.50 more for the tool to replace it.
