Originally Posted by Total Loss
Sounds like your steering on the toad is not free enough.
Is it an electric assist rack?
Go to a parking lot and have someone sit in the vehicle and make some sharp turns back and forth. They can watch teh movement of the steering wheel.
They can also watch from outside- see how quickly the wheels turn after the motorhome turns.
That ZR2 should NOT push you around in a 27 ft mh.
Yes the steering is going to be our focus. Yes we do have electric assist. As I said GM suggest a negative battery disconnect and we are not entirely sure why the negative. But maybe this has something to do with disabling the steering or not? I do understand why the battery disconnect and do have the positive disconnected while towing.
Scenario; driving straight and in perfect condition and we make a lane change truck doesn’t seem to respond to with the MH immediately and feels like it’s resisting the movement. Almost like it’s a delay in responding to the MH or fighting the transition. But then will straighten out and comply. Now add gusts, windy roads, speed and downhill and its worst. Thanks for the vote of confidence for the ZR2! And your feedback!
