Old 02-03-2019, 05:53 PM   #1
Hitch mounted bicycle rack for 3050s
Hello, we have recently purchased a sunseeker 3050sClick image for larger version
ID:	196111. We are upgrading from a travel trailer, i have started to look at some things that i need now that I’d didn’t need when towing trailer and the first is a hitch mounted bicycle rack. I am looking for any suggestions or recommendations. I think i would like one that comes with a storage tray also so if i have any dirty items i can carry them there. I have found one which i attached a picture of if anyone has used this before or know of another brand your input would be greatly appreciated. Thank you
Chief381 is offline   Reply With Quote
Old 02-03-2019, 06:02 PM   #2
Flybob's Avatar
With that long hitch shank, you are going to have a lot of bounce. Might be better off with something with shorter shank.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 02-04-2019, 08:51 AM   #3
CharSolera's Avatar
Find one that is approved for use on RVs (many are not). On Amazon, search for "Swagman RV bicycle rack."
Charlene
and catpanions, Purrl & Lucy Lu
2014 Solera 24S
CharSolera is offline   Reply With Quote
Old 02-04-2019, 11:08 AM   #4
Total Loss's Avatar
I built one for the rear off my frame rail so I could have them above the motorcycle.
I used 1/4" square alum hitch tubing and it flexed too much.
Had to attach it to the frame of the motorhome rear wall with urethane bushings.
Rides solid. No issues yet after several thousand miles.
I can remove either the bicycles or the m/c without the other.
And it comes apart completely in less than 5 minutes.Click image for larger version
"If you are going through hell..keep going"
W. Churchill
Total Loss is offline   Reply With Quote
Old 02-04-2019, 11:11 AM   #5
Total Loss's Avatar
That unit you posted in the OP will flex like crazy and bounce up a storm.
W. Churchill
Old 02-04-2019, 07:29 PM   #6
rockfossilman's Avatar
Originally Posted by Chief381 View Post
Hello, we have recently purchased a sunseeker 3050sAttachment 196111. We are upgrading from a travel trailer, i have started to look at some things that i need now that I’d didn’t need when towing trailer and the first is a hitch mounted bicycle rack. I am looking for any suggestions or recommendations. I think i would like one that comes with a storage tray also so if i have any dirty items i can carry them there. I have found one which i attached a picture of if anyone has used this before or know of another brand your input would be greatly appreciated. Thank you
I think this much weight added to the tail end of your trailer could drop your tongue weight to a level that would cause towing control problems.
Rockfossilman - Western PA
Rockwood UL 2604ws - 2013 F150 w/MaxTow
"I'm a man, but I can change, if I have to. . .I guess."
Red Green
"Quando Omni Flunkus Moritati"
rockfossilman is offline   Reply With Quote
Old 02-04-2019, 07:47 PM   #7
OYO
Love our Swagman (RV approved). No rack or bike movement -0.
Check out the videos on eTrailer.com.
Not cheap. You don't always get what you pay for, but you rarely get what you don't play for.
OYO is offline   Reply With Quote
Old 02-04-2019, 08:19 PM   #8
World Wide Wanderer
wahoonc's Avatar
Get the RV approved hitch!
We have two bike racks. One goes on the toad, the other on the RV. The RV is a Swagman that is approved for RVs, the one on the toad is a smaller one that isn't approved for RVs but is lighter weight.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 02-05-2019, 10:43 AM   #9
geeman53's Avatar
We have a Malone Pilot bike hitch that is solid as a rock. Our bikes load easily and lock down tight .With a nice cover, our bikes arrive in fine shape. I am referring to long interstate trips to the Keys or Myrtle Beach on terrible roads. It never fails to see an rv pulled over checking loose or missing bikes.
2016 sunseeker 2250slec
1988 Jayco p.u.,Coleman Plantation p.u.,1989 Jayco class c, Coachman TT,1995 Little Eddie fthwheel,2007 Heartland Sundance 2500 lS fthwheel
geeman53 is offline   Reply With Quote
305, 3050s, hitch, mount, saunseeker, sunseeker
