Wonder why there's not a hot and cold low point? Every RV we've had before had both. Even my FIL's little 18' Jayco has both. Pretty nice, if the relief valve was open on the WH, it'd almost syphon most of it out. Brian, being there are hot water lines lower than the WH, might suggest adding a low point to the hot line too. Cheap add on, cheap insurance. Could probably drain some of it out of the outside shower. Never paid much mind to it on this one, but I'll probably add one now that I know this.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
