How do you drain the fresh water tank on a 2016 Forester 2861DS. We looked under the RV and couldn't find the drain. Also, where is the low point drain?
Linda and Lenny
1995 Jamboree 31N (2000)
1979 Tioga 25' bunkbed (first RV in 1992)
Open the larger storage bin behind the right rear wheel. You will see a small door against the back wall on the left side. Open it and you will see the water filtration system. There is a silver valve that you need to turn 90 degrees and the water should come out of the blue line underneath the RV. If by chance there is a cap on the blue line remove it. The fresh water tank will then drain.
Hope this helps.
