If its like mine, pull the drawer part way out. Look at the slides and you will see a black piece of plastic in the middle of the slide. Push down on it (one on each side) and continue pulling the drawer out. The parts of the slide attached to the drawer and the cabinet will separate. To reattach just line up the slides and push back in.
2012 Forest River Sunseeker 2300 Chevy
Looked up this tread and tried to pull out one of the drawers in my 2703ws kitchen. I can get the latch to release on the right side but not on the left side and it's the same on all of the drawers!
Pull it open and locate the black plastic pieces on the metal slides, then try pushing one side down and pulling up on the other side while pulling the drawer out.
Thanks for the reply. Not long after I posted, I found another thread that said as you describe and I had no trouble. I couldn't find this thread to post an "I found it." note.
This forum is a real boon to all Forest River owners.
The slides are ambidextrous? standardized? uniform?...Anyway it doesn't matter if you put one on the right and one on the left....they are all the same, but that means one of them is always upside down when they're mounted. The black lever to disengage the slide ALWAYS needs to be pushed down...unless of course the slide is installed upside down (which will be at least one on every pair). That side goes up.
__________________ If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
