08-09-2015, 02:16 PM
How to remove wheel simulator/hub cap from the wheel?
I was putting air in my tires this morning and dropped one of the steel caps from the valve stem. I think it went between the wheel and the wheel simulator. I also found out I don't know how to remove the wheel simulator. So how do these things come off?
Thanks.
Greg
2021 Micro Lite 25FKBS
2021 Ford F-250 XLT CCSB 4wd w/ 6.2l and 6 sp. transmission, 3.73 locking axle
08-09-2015, 02:23 PM
Average Joe
Working around the wheel, pry it off with a flat screwdriver. Don't just pry in one spot or you'll bend the simulator.
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
08-09-2015, 04:08 PM
Claw hammer. Be careful not to bend.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
08-09-2015, 04:37 PM
I tried that and it did not want to budge so I decided to wait and ask here to make sure I was doing it right. Will try again next weekend at the storage lot.
08-09-2015, 05:28 PM
Tap on lugs three are attached take those off with proper socket
OK question Time...
2016 Georgetown 335ds
Larry and Judy Crossman
Lancaster NY
08-09-2015, 06:59 PM
Average Joe
My Sunseeker is different than this. Mine is just like a hubcap.
Joe and Karen
08-09-2015, 07:07 PM
Thanks.
Greg
Like others have said they come off like a regular hubcap, on the sunseeker.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
08-10-2015, 08:25 AM
Wait till next year...
X 2 Claw Hammer works just be careful about bending edge and work your way around slowly
Mary and Me
2015 2650s "Finally" SOLD
2015 Jeep Cherokee Toady
2023 Geo Pro FD19 "Almost there"
2022 Race Car Red HR Long Ford Transit 250 "The Iwish Roamer"
08-10-2015, 08:32 AM
I bought a little L shaped nail remover, about 10" long, and pry in 2 or 3 places and it pops right off. Use my hand or a rubber mallet to put it back on.
08-10-2015, 08:43 AM
DO NOT PRY YET! 3 of the 10 chrome lug nut covers are actually threaded and hold the simulator on. On mine you MUST remove them first or you will destroy the simulator. Look closely at the lug not covers. 3 of them are slightly different at the bottom. You SHOULD have received a tool to remove those 3 first. It is possible you don't have this type, however CHECK.
08-10-2015, 08:59 AM
If your simulators are this kind there will be an indentation near the base of the lug nut covers that need to be removed with the special tool that should have been provided to you. Could be 2 or 3 have to be removed. then the simulator will pop off.
08-10-2015, 11:35 AM
The video I found on YouTube for a horse trailer showed that as well. I couldn't find much else about these wheel caps. I will check to see if some of the lug nut covers screw off before I start prying.
08-10-2015, 11:36 AM
Go to Northern Tools, Ebay or your local automotive store and pick up a Grip Tools Tire and Hub Cap Remover, Model# 52114. See Here. They make the job a lot easier and you are less likely to bend the hub cap / simulator taking it off and putting it back on....
Wayne
2024 Sunseeker 2150SLEF / Ford E-350 Due for delivery 24 April 2024.
08-10-2015, 11:40 AM
Harbor Freight or similar carries what is called a rolling bar one end has a hook works great I had only from my Mill right days.
08-12-2015, 07:05 PM
Harbor Freight has this tool also. Works great at removing and replacing. Just pry around the rim in several spots and it will finally just pop off. Putting it back, make sure it is lined up properly (the fake lug nuts positioned over the real ones) and use the mallet end to hammer on in several places. Takes a little effort, but will eventually pop into place.
2012 Forest River Sunseeker 2300 Chevy
08-12-2015, 10:30 PM
Our 1997 Minnie Winnie had a couple of lug caps you had to take off before removing the beauty ring. Does anyone know for sure whether the 3170 or 3171 do or do not have lug caps that need removing before prying?
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
08-13-2015, 09:39 PM
My 2014 3170DSF, the wheel covers are one piece and just pop off with a little effort.
08-14-2015, 07:00 AM
You may or may not have this type.
It is easy to see. Just look closely at the faux lug nut covers. 2 or three of them will be different at the base where they meet the chrome flat section. If you have them you will need to turn them off first. Then the wheel cover will fall right off.
08-14-2015, 08:08 PM
Jim, I did look at them closely, and they all look the same to me. I think they are the same as Garrett's wheel covers. Should be safe to pull off with one of the above pictured tools.
1968 tent trailer
1985 Jamboree 23 ft
