Consider the next owner
What about the guy you sell your RV to next year? He may move to Colorado, and then he'll be in serious trouble. Or what if you get unusually cold weather? Even Florida freezes sometimes, and I saw snow in Tucson once. If you just plug it, any water left in the system will be in a rigid fitting, which will crack instantly if frozen.
I'd buy a 90 degree SharkBite fitting that pushes on to the tubing. They work great. You could probably just cut the tubing still on the 90 degree fitting, or use a Dremel with a cutting blade to cut the crimped ring.
