Old 01-25-2018, 09:52 AM   #1
Question How to start cold generator
I have a 4000 Onan generator in a 2017 Sunseeker that is hard to start when it is cold. I do not think I'm priming it properly? My toggle switch for starting the generator is also my prime/stop switch when the lower half is pushed. I see some folks talk about a light that comes on. I am pretty sure I do not have a light, I've never seen it at least. I am not even sure the switch does anything? Can someone tell me the correct procedure for starting the cold generator? How long to depress the switch if there is no light? How to tell if it is even doing anything? Thank you in advance.
JohnGaines is offline   Reply With Quote
Old 01-25-2018, 09:59 AM   #2
sgtlm17's Avatar
Does pressing the start switch inside the coach actually crank the generator?
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 01-25-2018, 10:05 AM   #3
Originally Posted by sgtlm17 View Post
Does presiding the start switch inside the coach actually crank the generator?
Yes the start switch works fine. I usually have to crank the generator for 30 seconds at a time and it takes several attempts.
Old 01-25-2018, 10:13 AM   #4
sgtlm17's Avatar
Ok before you start the generator when you press the stop prime button the red light should come on within about 10 seconds give or take a second or two. Listen carefully or have someone listen at the generator you should hear the fuel pump. If you hear the fuel pump then the prime button is working. Some of these units are pretty tough to turn over and you need your batteries pretty well charged. Also there is a start prime button on the generator itself. Try using that button to see if it works any better. Fuel pumps on these things are notorious for causing problems. It may work but it's possible it's not working as it should. I will say my unit is tough to turn over and takes a good 15 seconds or so.
2011 Jeep JK Toad
Old 01-25-2018, 10:24 AM   #5
Usually it takes 20-30 seconds to prime the unit, This is how we have done ours and it usually fries right up. Ours does not have a red light that comes on. Never did and there is no red light on the switch.
2014 SUNSEEKER 3010DS
TOADS, 2012 FOCUS OR 1998 JEEP WRANGLER,
Kevin & Judy is offline   Reply With Quote
Old 01-25-2018, 10:27 AM   #6
2014 SunSeeker 2300
Awilson's Avatar
Mine does not have a light inside either and mine is also hard to start if it is cool outside. I have started mine down as cold as 5 degrees and it took three tries. I held the prime switch down for about five seconds and then hit start. On mine it takes holding the start button longer than what is comfortable and it will start firing. When I feel itís time to give the starter a break I stop and wait for a minute or so and try again with priming etc.
To follow this up, I reread my manual and the prime switch is to be used when the genset has been run out of fuel, then, hold the prime switch for 30 seconds. The starter has over-cranking protection and will stop on its own after 15-20 seconds. My manual says to hold the start button till it starts. If it didnít start first time try again. I learn new stuff all the time. Actually, I relearn what I forgot with some posts. Lol!
. We are now retired and living the dream! 2014 2300 SunSeeker without slides that we remodeled inside for better living conditions for two people.
Awilson is offline   Reply With Quote
Old 01-25-2018, 11:07 AM   #7
Empty Nesters
KenandCarol's Avatar
I have a 2017 Sunseeker 2150. I hit the generator to stop/prime and I can definitely hear the fuel pump running. After about 20 seconds a red light comes on above the switch and I toggle to start. It usually fires right up. I have never done it in really cold weather since I live in warm California.
2017 Sunseeker 2250 24' MH
KenandCarol is offline   Reply With Quote
Old 01-25-2018, 11:19 AM   #8
bubbles's Avatar
I think the illuminated prime/start switch is part of the Onan generator installation kit. never seen one with a switch that didn't illuminate for prime and illuminated while running. Oh well. Can the ones that don't illuminate post a picture of the switch?
Old 01-25-2018, 11:55 AM   #9
Just something to Think about in regards to "Cold Start" of Generators! These generators Start & Run at 3600 RPM under a Very Quick "Full Load"! Most MFG consider 35 Deg F "COLD"! Some MFG sell "Cold Start Kits" that heat the engine Oil and the Battery,thus the Engine is not starting without proper lube,even with the Oil Viscosity called for "COLD Weather Use"! How many FRF Members change the oil in there Generators for COLD Weather Use? Youroo!!
Old 01-25-2018, 12:21 PM   #10
2014 SunSeeker 2300
Awilson's Avatar
Lol! Warm California! Rub it in! We left home to get out of -15 degrees and 25 mph wind!
Old 01-25-2018, 12:26 PM   #11
2014 SunSeeker 2300
Awilson's Avatar
Well, I just was going to take a picture of mine that doesnít have the light and Iíll be danged! It does have the light! 🤭 Iím now quite humbled and obviously getting older and more forgetful.
This post is just one reason I love this forum. I read them a a lot and learn many things on here.
Alan
Old 01-25-2018, 01:19 PM   #12
can you see the light in the picture? Maybe mine has a light as well and I just can't see it? Do you know when the light should be on?
Old 01-25-2018, 01:25 PM   #13
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
I don't have a generator, but always keep a can a fuel starter to squirt into the carburetor throat of my small engines. Snow blower, chain saw, etc. Engines that won't fire most always come to life this way.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Rockford, Michigan
Lloydg is offline   Reply With Quote
Old 01-25-2018, 01:42 PM   #14
BobHanke's Avatar
There is a light that comes on when holding the prime/stop switch down for a few seconds. Must repeat the start sequence several times in cold weather. It wouldn’t hurt to run the engine when trying to start a stubborn genny. It is also possible to have a bad wire in the remote group. Have someone listen at the genny when remote starting if you can’t hear it prime or no light inside.
BobHanke is offline   Reply With Quote
Old 01-25-2018, 01:46 PM   #15
The issue with my hard cold-starting 4K was that the choke rod gets stuck in the "OFF" position. Other's have had the same issue. I can manually move the choke rod to the "ON" position and it will start right up on the first push of the button.
ActionJackson is offline   Reply With Quote
Old 01-25-2018, 01:48 PM   #16
Empty Nesters
LOL! It got a little chilly on Monday (34*F) and I actually had to scrape some ice off my windshield. That's the coldest we've been in January this year. Luckily it warmed up to the low 60's by the afternoon!!!
Old 01-25-2018, 02:10 PM   #17
2014 SunSeeker 2300
Awilson's Avatar
We are in Arizona now enjoying the heat and away from this crazy cold we've been forced to deal with! This thread got me to start my genny up as it hadn't been started in a few weeks. I can say it is much easier to start here than at home. I have never had the issue of the choke staying off so I have no suggestions as to a cure.
Old 01-25-2018, 02:12 PM   #18
bubbles's Avatar
Typically the switch is held in the prime position (down) till the light comes on then hold the switch in the up position for start and when started the light will come back on while the genny is running. This is the Onan procedure for my Onan 4K genny, It was also the procedure for the 7K gennies I've had.
Old 01-25-2018, 02:19 PM   #19
grumpy0374's Avatar
A known problem with the 4000 is a sticking choke linkage. Occasionally when I start mine, if it won't cold start, I go out and open the compartment, take the front cover off.
Manually kick the linkage open, and using the prime/start button, prime it, and it will start right up.
After running for awhile, shut down, and restart 30-60 minutes later from inside...it starts right up.
Some of the 4000's do this and some don't. Luck of the draw.
Grumpy
Steve & Cheryl + Zoey, and Ziggy, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
grumpy0374 is offline   Reply With Quote
Old 01-25-2018, 02:29 PM   #20
Tom48's Avatar
I'm at about 1000 ft sea level elevation, yet on cool or cold days I prime twice and the start. Often takes two tries. Seems normal for us. We start and run it under load about once a month. It would probably do better if we used it more often. Be sure not to let your gas get too old. We fill and use the tank full about twice a year. That's probably gas that's a bit too old. Vi should be using an additive like StaBil or Seafoam more often to keep the gas healthier.
Tom48 is offline   Reply With Quote
generator
