Old 06-14-2021, 11:22 PM   #1
Hydraulic jacks
Have a 2021 forester can someone tell me where the hydraulic jack valve body is located
Jackcatt is offline   Reply With Quote
Old 06-14-2021, 11:40 PM   #2
bikendan's Avatar
You need to post which model number you're asking about since the location is probably model-specific.
Old 06-15-2021, 06:08 AM   #3
Kanadian Kamper
kenandterry's Avatar
You need to provide more specific details for the model of your rig for people to help. There are a number of Forester models.
In the meantime, have you looked underneath your rig? Quite often, these hydraulic units are visible from the underside.
Ken and Terry
2018 Sunseeker 2430S-CD
and if we ever need it, can be pushed by our 2017 GMC Terrain toad (4 wheels down)
Former Georgetown 330TS owner for 10 years with more mods than I can count.
kenandterry is offline   Reply With Quote
Old 06-15-2021, 10:13 AM   #4
Ambassador Member
Duckogram's Avatar
I consulted with Carnac the Magnificent and the answer is:
Inside the left (drivers) chassis frame rail about midships.
Best viewed from the passenger side with a good flashlight.
Just Ducky
Towing Smart
No PMís (they are not private anyway)
Posting exclusively* in the Forester/Sunseeker section.
The ignore function is the electronic version of a smelly sweat sock in the pie-hole.
Old 06-15-2021, 02:22 PM   #5
While you are under there checking the fluid level, i strongly - VERY strongly - advise/encourage also checking the 2 bolts that hold that pump to its bracket. Without those 2 bolts the pump can hang upside down from the hoses for some time; luckily i do not know how long. Two new bolts with double locking nuts are now holding mine.
billw
2020 Forester 3011DS under 5k miles
billw
billwww3 is offline   Reply With Quote
Old 06-16-2021, 12:57 PM   #6
Thanks found it
Old 06-16-2021, 01:49 PM   #7
Kanadian Kamper
Thanks found it
Unless itís a secret, maybe you could let others know where you found it that may read this thread, in case they have an issue.
Ken and Terry
Old 06-16-2021, 02:38 PM   #8
Found
As suggested it is just forward of the driver side rear wheels on inside of the chassis frame, up pretty high, doesn't look like it's easy to fill resivior, or operate manually. My unit is a 3051s forester!
Old 06-17-2021, 11:50 AM   #9
Ambassador Member
Duckogram's Avatar
I suggest you use a hand pump (photo attached) to fill the reservoir. As for manual operation, that is beyond hazardous.
Just Ducky
Towing Smart
Old 06-21-2021, 12:34 PM   #10
Leveling jacks are giving me an error message saying they did not full retract. They seem to be completely up to me but I’m also getting a “service soon” message and now they will not operate at all. I have a ‘21 Sunseeker 3040ds and feel like I need to check the fluid but how do I get rid of the error message?
Bkeeley is offline   Reply With Quote
hydraulic, jacks
