Originally Posted by Mike & Molly
I discovered that the radio/GPS/CD player in my 2013 3010DS is wired hot.
In other words it works with out the key in the ignition or in the ACC position.
Dealer thinks its wired to the house batteries as well as the chassis battery. How can that be.
Wouldn't it have to be one or the other?
As mentioned above, we have a little relay that senses voltage. That way it will run off the chassis battery like normal, but when parked it will switch to the house batteries...so no need for a key.
Just make sure when you want to turn it off (you don't just turn it down as it will continue to draw power). Push and hold the power button (top left) for about 3 seconds. It will beep and power down.
