Old 11-06-2014, 10:10 AM   #1
blythepyrate's Avatar
Interior condensation: what to do?
I noticed condensation along the front of my overhead and in the cabinet above the refrigerator. I have vent covers and keep my vents partially open all the time. How else can I fight the condensation?
Pyrate
Fuzzy Bear (Newf) & Emmett (ginger cat)
2009 Sunseeker 2900 & Jeep Cherokee Sport
blythepyrate is offline   Reply With Quote
Old 11-06-2014, 10:16 AM   #2
AKA: 'tiredTeacher
awellis3's Avatar
Get one of these:LG LD301EL: 30 Pint Dehumidifier | LG USA
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 11-06-2014, 10:23 AM   #3
I have always made it a habit to prop the cabinets open when the unit is stored and when I run the heater...
2010 Georgetown 300FWSSouth Florida
speedjester is offline   Reply With Quote
Old 11-06-2014, 11:05 AM   #4
LKicklight's Avatar
MILDEW
Had that same problem last year with the Sunnybrook. Since it does not get any direct sunshine on it because of the full awning cover, mildew has been a bad problem. While we gone to Alaska this summer, we used a Dehumidifier unit with the drain line run to the shower. Since the coach is hooked up to exterior black water septic tank, the water just runs out. When we reurned after 4 1/2 months, the Rv inside was great, the air inside had a scent almost like rose's. Today in the fall, we supplment the propane furnance with electric haet, does a good job as the propane does have a high moisture content.
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
Old 11-07-2014, 07:32 AM   #5
Mikegjax's Avatar
Two large containers of Damprid also helps.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 11-07-2014, 07:45 AM   #6
RKR
RKR's Avatar
X2 on the Damprid. I used 3 last year and they collected a good amount of water. Pretty cheap and maintenance free fix. Two in the main area and one in the bedroom.
I left the 5r locked up all last winter and it had no musty smell when we got back in it. The Damprids were about 3/4 full of water.
Sent from my high tech gadget
RKR is offline   Reply With Quote
Old 11-07-2014, 07:48 AM   #7
CSMRetired's Avatar
Damprid
'Pa Pa's Palace'
2014 Sportscoach Crosscountry 405FK
2015 Jeep Grand Cherokee Overland
CSMRetired is offline   Reply With Quote
Old 11-07-2014, 08:30 AM   #8
Although it would seem logical to vent the coach it is best to keep it tightly closed up. Temperature changes and moist air coming in the vents causes the condensation. The best would be run a dehumidifier but a couple buckets of damprid will work for shorter terms.
ATVer is offline   Reply With Quote
Old 11-09-2014, 11:36 PM   #9
I will echo the Damprid. We use the hanging ones year around. While they aren't the most beautiful to look at they do work well in the damp Western Oregon. We can get out most year around and tend to head to the coast so they are worth the five bucks or so. I keep one in the bedroom and another in the living area.
I have had one start to leak at a seam but it might have gotten pinched in a closet door. Had another that was iffy so out it went.
RedRollingRoadblock is offline   Reply With Quote
