Old 05-06-2016, 11:08 AM   #1
Delco Bobby's Avatar
Is there a stud here?
The photo shows a vertical area that frames in my shower on the right side when facing the shower. This is on a Sunseeker 2250.
So, is there a stud behind this trim? Anyone know?
I want to move the TP paper holder to this spot to move it out of the way. I am not concerned with getting the paper wet from shower water as I can always move it prior to using the shower (if I was remotely able to squeeze myself into the shower).
Ideally, I would like to use some screws to attach it to the wall. that is the reason for this question.
TIA,
Bobby
2017 Dynamax REV 24RB
2018 Ford F-150
Delco Bobby is offline   Reply With Quote
Old 05-06-2016, 11:12 AM   #2
Who Dares, Wins
doc73's Avatar
Is that end molding (on the left side) a plastic C channel? I have a similar wall in our TT that is just a small piece of maybe 1x1 or 1 x3/4 under the C channel then hollow through the wall to where it connects with the interior main wall.
2015 Chevy HD D-Max
2022 Impression 315MB
doc73 is offline   Reply With Quote
Old 05-06-2016, 11:28 AM   #3
Phat Phrog Stunt Crew
elind's Avatar
I would just drill in anchor screws anywhere just as long as they are shorter than the thickness of the wall. OR use Command strips that have 16-25lb holding power.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 05-10-2016, 12:53 PM   #4
Hoglou's Avatar
A finishing drill trick. Take a long sewing needle tape off at 1/4" -3/8" mark and drill with it. Remove the needle and use it to see if there is any restriction or stud behind it. White tooth paste and a little brown powder from DWs make up drawer and you will never find it. Ever needed to drill from one baseboard all of the way to he other side? Drill with a coat hanger about 10" with angle cut on the end....
X2 on the command strips..
Hoglou the DH & BK the DW (retired and happy)
WestGA KM4HQQ 146.640mhz
Check out the "mods" in the albums
