10-19-2015, 08:20 AM
Jensen Exterior Radio
Has anyone had any trouble with the Jensen Exterior Radio turning it self on ??? We found ours on Saturday & again Sunday ???
10-19-2015, 08:32 AM
Not sure if this would be the same thing I found, but I'll tell you what worked for me. I would plug my camper in and the radio outside would come on. What I was doing was putting the radio into mute and not turning it off. When you hit the power button quick it will be in mute. You can see that on the screen. Hold the button down for a few seconds and it will turn it off. I haven't had mine come on by itself since I found that out.
10-19-2015, 09:20 AM
Thanks for the info,,, we have tried holding the power bottom,,,
And it just keeps playing ??? Only way he have been able stop it was to tap the bottom,,, we will try hold it again and see if that works,,, I know that is the way Jensen told us to turn it off ???
Thanks Brian !!!
10-19-2015, 03:01 PM
Ha! Camping and just a few minutes ago DW asked what is that hissing? Damn radio on again. I am just about ready to remove that radio and turn the space into a four bottle wine caddy. 2.5 years and the radio just comes on all by itself. No rhyme or reason.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
10-20-2015, 08:20 AM
CRAZY hey !!!
Sunday I turned ours off & on a couple of times,,, then off,,, did not come back on yesterday while we were winterizing,,, I now have the batteries turned off,,, so guess it will not come again till spring ???
LOL !!!
PS: have never found a way to turn Dash radio off,,, we just turn the volume as low as we can,,, seams as if the GPS is on,,, so is the radio ???
10-20-2015, 04:36 PM
If you have a magnadyne unit, just pushin the reset button and hold until it turns off. Of course you will loose all of your settings and saves. Located in lower left corner. Use a ballpoint pen or appropriate object.
10-21-2015, 06:20 AM
Yes we have the Magnadyne,,, we know how to turn the complete unit off,,, just have never found a way to only turn the radio off ???
Because of the very poor reception we never lesion to it anyway !!!
Last year after we bought the MH,,, we keep hearing something that sounded like music,,, even though we had the volume as low as it would go,,, I traced it down to an outside compartment under the dinette,,, it was a Sub Woofer,,, that sub woofer has been in a box in the basement ever since !!!
10-21-2015, 10:12 AM
On the Magnadyne, if you want the GPS on but no radio, tune the radio to a source that you do not actually have (AV1, XM, etc.). You will not hear anything, but will still have the GPS audio.
2012 Forest River Sunseeker 2300 Chevy
10-22-2015, 07:04 AM
That would be worth a try !!!
12-26-2015, 04:44 PM
I added a switch
I had the same issue in my 04 Winnebago. Outdoor radio would come on by itself. So I added a toggle switch. Just did the same on my New Forester along with changing the Upper outdoor speakers from dash radio control to the Outdoor radio. Switch by radio cuts power to radio and TV.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 6 trips 19 nights
2020 Camping 0 trips Cancellations 6
12-26-2015, 06:08 PM
Yes, we had the same issue with our Jenson radio coming on by itself. The first fix was to put a cutout switch to cut off the 12v power to the radio, when not in use. After the installation of the switch, we developed another issue with the radio. While in FM mode, it would start trying to load a CD, which was not inserted into the radio. Primetime finally sent me a replacement Jensen and I have not had any issues to date with the replacement.
 BTCM(SW) Ret USN
2013 Sanibel 3500
2013 Ram Truck 3500 Laramie Longhorn Dually
12-27-2015, 07:21 AM
I have also found outdoor radio on a couple of times ???
Only in the world of RVs I guess ???
01-01-2016, 11:50 AM
Do these have a DVD player built in to them? I am not around my rv to check.
I noticed the sound on the radios were pretty bad, was thinking about ripping them out and putting a decent system there
2014 SunSeeker 3170DS
Ford F-450
01-02-2016, 10:23 AM
If you are talking about the dash unit,,,
I believe the problem in the antenna !!!
01-03-2016, 12:44 AM
No the outside unit !
Ford F-450
01-03-2016, 08:40 AM
Outside, yep. No cure short of removal or isolation switch.
01-03-2016, 09:06 AM
Our outside radio sounds pretty good,,, very seldom ever use it,,, maybe @ home when I am working on the MH,,, Camping we like Peach & Quite !!!
As do I think our neighbors do also !!!
