Jensen TV voltage drop
2016 3010DS. Jensen TV when turned on reduces voltage from that connection from 12 volts +/- to 10 volts or less. When dry camping, the tv will stay on until almost anything else is activated (water pump, furnace motor, etc), then tv shuts off. Can be turned back on once offending other device is turned off.
Coach batteries are less than one season old and show consistent 12 volts +, while this is going on, (plus good hygrometer readings) and monitoring 12 volts outlets elsewhere in the coach shows they maintain the proper 12 volts + level.
Any ideas?
