Old 10-30-2018, 03:58 PM   #1
Jensen VX7020A unit frozen
The system powers up just fine and I can see all of the menu items but the touch screen will not work. Iíve hit the reset button a few times and I still cannot touch any of the menu items. Has anyone else had this problem?
ksdindy is offline   Reply With Quote
Old 10-31-2018, 11:45 AM   #2
Shredder's Avatar
Nothing a big hammer wont fix. J/K. I did have this problem i have to remove the unit from the dash and i disconnected the large plug from the back of it. What a pain trying to get it out of the dash uggggg. I left it for a minute or so and reconnected it. Everything still works fine. Hopefully it helps you out.
Bob
2013 Forest River Sunseeker 3010DS
Shredder is offline   Reply With Quote
Old 10-31-2018, 01:08 PM   #3
Ugh. I really donít want to have to do that. I wonder if removing the fuse or disconnecting the battery would have the same effect. I donít know what effect removing the battery would have on the rest of the equipment? And I also donít know where exactly is the fuse boxes located that controls the radio. Itís not in the camper and itís not under the hood. I canít seem to locate the fuse box any where else
Old 10-31-2018, 02:11 PM   #4
Shredder's Avatar
I have 3 fuse boxes 1 under the dash drivers side probably where the fuse you are looking for is located. 1 under the hood drivers side close to the headlight and 1 under your bed in the rear of the unit. Good luck in finding the fuse it wasn't an option for me as there was so many of them and no one really had a definitive fuse box layout.
Bob
Old 10-31-2018, 06:16 PM   #5
Usually Confused Member
emm-dee's Avatar
Fuse panel left sidewall near parking brake. Fuse #39. 20 amp.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
emm-dee is online now   Reply With Quote
Old 12-06-2018, 07:14 PM   #6
Jense VX7020
ksdindy, did you solve your Jensen issue? If so, how? I am having the same problem.
Marnenorden is offline   Reply With Quote
Old 12-06-2018, 07:32 PM   #7
Nope. Itís in the shop now getting looked at. Not sure if they are going to have to replace it or they have a fix for it. I probably wonít know until later this week
Old 12-06-2018, 07:38 PM   #8
Mine does now and again, but likely only when using the nav and xm at the same time. I suspect it simply does not have enough working memory, so I no longer use the nav. I have been able to reset button removing power.
The map company it uses is a couple of years behind Google maps... even when updated.
Dp26 is offline   Reply With Quote
Old 12-13-2018, 07:20 AM   #9
Mine is being replaced under warranty. Defective unit.
jensen
